Old 09-15-2009, 07:25 PM
cali9dub cali9dub is offline
Default bounced tracks not dropping in properly
I have read several posts on here regarding bouncing and exporting individual tracks. My specific problem is as follows:
I am trying to bounce individual tracks to share with a fellow DJ out in California to make a mix. Every time i bounce a track and import it back into pro tools it doesnt start where it should. For example if a portion of beat starts at 3|1|0 the file that i bounce and then import (or drag and drop...makes no difference) will start audio at 3|2|0 or some point later than that.
I have tried consolidating the track then bouncing, compacting the region then bouncing or exporting the region (neither works). I have elastic Audio disabled during all of this.
What am I doing wrong where I cant get the audio to export so it properly starts at 3|1|0 like in my mix in pro tools?
Thanks so much for any help !!
Old 09-15-2009, 07:31 PM
Dism Dism is offline
Default Re: bounced tracks not dropping in properly
Consolidate the region so that it starts at zero (0|0|0). To do this, select the region in question, hold shift, press return (which creates a selection that includes the region, but starts at zero). Now consolidate (shift+option+3). What this does, is it creates a region that starts at zero, but the audio should come in at it's desired location. All the "dead space" before it should be at 0 volume, provided there was nothing there to begin with.
This is how I bounce tracks for import to other software, and it works every time.
Old 09-15-2009, 07:35 PM
flommer flommer is offline
You could be suffering from latency.. Do you have any plugs on your stereo master fader (or aux if you do it that way)..?
Instead of bouncing to disc, try recording to a new stereo audio track. You should be able to see very quickly if the new audio is lagging behind..
You could then slide it around until it is correct again (look for strong transients to match up with an original track) then consolidate..
Probably other methods as well..
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 09-15-2009, 07:36 PM
Then you just bounce to disk? Any format preferred over others?
Oh....I only have 1 plug-in on the master.
Old 09-15-2009, 07:41 PM
Rather than bounce to disk, use Export Regions as Files, from the Regions side bar. Select the recorded audio, press shift+command+k. Pretty sure latency shouldn't have anything to do with export.
Old 09-15-2009, 07:46 PM
And what plugin is that? It could be introducing a lot of latency..
And yes, if you get your mixdown track inside ProTools, then export instead of bounce..
Old 09-15-2009, 07:48 PM
Izotope Ozone is the plug-in, which I want applied to the bounced tracks.
Old 09-15-2009, 07:52 PM
Thanks Dism..does elastic audio need to be disabled? and does it matter after that if the track is tick based or sample?
Old 09-15-2009, 07:55 PM
Best thing to do is follow flommer's advice, and record the audio to a new track. To do this, bus the outputs of each track you want included in the mix, to a new audio track.
i.e. Change the output of the track you wish to record from to "bus 1-2", and the input of the track you are recording to, to "bus 1-2". Change the output of the Master channel to "bus 1-2" as well. Then record as you would normally to the new track.
You will be able to see in the new track whether or not latency is your problem. If everything is lined up as you like, export (shift+command+K) the region, and everything should be lined up properly.
Old 09-15-2009, 07:59 PM
montezuma montezuma is offline
Just to mention (NOTE: i'm not necessarily saying it's the cause of your problem) - from my experience Ozone introduces a HUGE plug-in delay - the largest i've seen out of all of my plugs (and I use a fair few).
I once bounced a track with Ozone on it, and compared it to the original - you could audibly hear the delay on the "Ozone'd" track (i.e. when playing both tracks with everything else muted, you could actually hear the two tracks DISCRETELY - it was that bad!), and you could see the misalignment in the waveforms in the edit window when you put the two tracks one above the other.
Thought I would mention this, JIC. Apologies if it is unrelated to your problem.
Is there any way I can get 128 instrument tracks without dropping 2 grand?? Violet Pro Tools 9 10 10-18-2011 12:18 AM
Pro Tools dropping tracks at 96 khz friendlybunny Pro Tools TDM Systems (Mac) 1 02-08-2011 09:52 AM
midi tracks dropping levels while recording elv1s1sal1ve 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-03-2008 08:16 PM
Bounced .wav file doesn't work properly Digger Dan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-10-2006 03:43 AM
tracks dropping out... terryd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-04-2005 07:38 PM
