Old 03-27-2004, 11:59 AM
Ignatius Reilly Ignatius Reilly is offline
Default Signal path for turntable
I'd like to start playing around with saving some of my vinyl onto CD, sampling, etc. I'm wondering if anybody out there has used their DIGI hardware for this and/or has any info on the signal path of amplification from a magnetic cartidge on a turntable into computer. I've got a little Mackie 1202 mixer I could dedicate to the project. It seems like with the various pre-amp stages and gains available between that and my 001 (soon to be 002R), I wouldn't need another preamp or stereo receiver. I know I can experiment, but I just want to make sure I'm not missing something obvious that would screw everything up.
Old 03-27-2004, 12:04 PM
hobo123455 hobo123455 is offline
Default Re: Signal path for turntable
I clean up some old records for an older country artist. I used the waves restoration plugins which are great BTW.
Old 03-27-2004, 12:42 PM
Chris Cavell Chris Cavell is offline
you need an RIAA rated phono pre...www.paia.com has some for very cheap if you're inclined to build it yourself, I think ART makes one too.
Cavell Studios
Old 03-27-2004, 12:53 PM
the riaa curve can also be done with a plugin, so you'd really just need a preamp to get the output of the cartridge into ProTools.
Quad 2.5 G5, 4.5G RAM
Old 03-27-2004, 04:13 PM
3JDamon 3JDamon is offline
You need a proper RIAA preamp that also matches impedence properly. A receiver does the trick fine, probably the cheapest thing that offers a better circuit path is a Soundcraft Notepad for about $150, whose stereo line inputs can be switched to RIAA standard. It also has substantially better preamps than your Mackie (I've compared them side-by-side). If you modified it to have inserts on each mic preamp it would be a good cheap way to add 4 preamps for the 002R's line inputs.
Old 03-27-2004, 05:22 PM
6969 6969 is offline
This is how I do it
Turntable RCA L and R to
Art DeeJay Pre RCA INPUT left and right
Art DeeJay Pre RCA OUTPUT left and right to
Digi Box 1/4" Analog channel 3(L) and 4(R)
I then go into HARDWARE setup and adjust the INPUT GAIN to get the hottest level without clipping.
The Art DeeJay Pre is under $50 I think.
Hope this helps.
DJ
6969
Old 03-28-2004, 07:40 AM
where02190 where02190 is offline
YOu should adjust the input sensitivity for the output sensitivity fo the mixer, most likely either -10dbV(if it's RCA) or +4dbu(if it's TRS or XLR) See the manual or the manufacturers website for specs.
firewire signal path nplmdthfan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 07-15-2010 03:10 PM
Signal Path (for an 001) Cavet Your Eruptor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-28-2006 12:55 PM
Signal Path bluesna Tips & Tricks 0 01-10-2005 01:02 AM
signal path plug-in nightshade crisis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-09-2002 11:31 PM
C 24 signal path (does this look right?) sidereal ProControl, Control|24, Command|8 3 03-19-2001 01:12 AM
