Old 01-25-2024, 11:32 AM
garnoil garnoil is offline
Default Still disconnecting from Pace authorization and I-lock
I started getting this when I upgraded to my Mac Studio Ultra 2. Several times a day all my plugins will disconnect form their authorization on I-lock and Pace. It forces a re-boot from cold. Before someone suggested that I plug my I-lock directly into the computer port and I did that, but the issue persists. Any ideas, very annoying and time consuming.
Old 01-25-2024, 02:02 PM
cvicente22's Avatar
cvicente22 cvicente22 is offline
Default Re: Still disconnecting from Pace authorization and I-lock
Hi Garnoil,
May I ask what operating system are you using as well as the version if your Pro Tools? Have you also tried checking for any update for your iLok license manager?
Regards,
Charles
________________
To create an Avid Support Case, you may go to https://www.avid.com/learn-and-support/contact-audio-and-music-support
Old 02-21-2024, 04:18 PM
Ventura 13.5, I-lock license manager is up to date Mac Studio Ultra 2G
G
Old 02-22-2024, 05:55 AM
cvicente22's Avatar
Have you also tried to update those plugins that you're having problem with?
Regards,
Charles
________________
Old 02-25-2024, 04:19 PM
How is the iLok connected? Is it on a hub? Try moving it to a port on the computer? Are you using Cloud authorization? That requires a 100% bulletproof internet connection and I would skip the cloud and use a physical iLok
Old 02-26-2024, 11:05 AM
All of the plugins loose contact with the I-lock and the actual I-lock Key is connected to the computer and NOT through a hub, directly into the computer port, All of the sudden a big red notice appears and says that I- lock is not found. Re-boot from cold fixes the issue, but it is very annoying.
Old 03-01-2024, 01:58 PM
Leverson Leverson is offline
I just wanted to say that I'm also seeing this same kind of error as well. Not daily, it's more rare for me, maybe once a week or so, but it is still random and annoying when it pops up and forces a restart.
Mac Studio M2 Max, running Ventura 13.6.4, and Pro Tools Ultimate 2023.9.0.
3rd gen ilok USB key (the small silver one) plugged directly into the computer itself (not going through a dock or hub), not using ilok cloud for anything, and running the latest ilok license manager software.
Can't seem to find a rhyme or reason to why it happens.
Old 03-02-2024, 03:09 AM
prspn prspn is offline
I also started seeing this when I set up a new Mac Studio M2 Ultra last year.
Lots of disconnects when using the built-in USB-A ports, not just with iLok but also various other peripherals.
I switched to using the USB-C ports with adapters or hubs instead, and the problem went away completely.
My impression was it's more of an Apple issue, but I didn't investigate any further once it started working reliably for me.
Old 03-02-2024, 06:35 AM
K Roche's Avatar
K Roche K Roche is offline
I wonder if that is the case (bad USB -A ports) in fact my 2020 intel iMac had a bad USB port right out of the box which I never took the time to have repaired, I just connected a hub to a functioning USB port and never looked back
System :
Enjoy the Journey
.... Kev...
Old 03-05-2024, 06:28 AM
cvicente22's Avatar
Hi folks,
I will check this with iLok as well to see if it is a bug or known issue on their end.
Regards,
Charles
________________
Error, missing PACE authorization for Pro Tools? JMengz Pro Tools 2 10-24-2021 10:37 PM
Error, missing PACE authorization for Pro Tools. rocketsurgery Pro Tools 2019 4 06-05-2021 04:05 PM
Pace/iLOK Authorization Shuts PT zsarbomba Licensing & Accounts 22 10-22-2020 10:23 PM
Getting PACE/Authorization Error For No Discernible Reason txlonelystar Pro Tools 2019 14 03-26-2020 12:26 PM
Missing PACE Authorization for Pro Tools CalebCuzner Pro Tools 2018 2 04-03-2018 06:17 AM
