Old 02-23-2024, 08:08 AM
Izzi Izzi is offline
Default Recording vocals with reverb into an SSL 2
Just picked up an SSL 2. How do I record vocals (with reverb) using the Monitor Mix on the SSL 2 into PT? I just want to hear the verb, not record it.
MacBook Pro (Retina, 15-inch, Late 2013), 2.3 GHz Quad-core Intel Core i7, 16GB SDRAM, MacOS Big Sur 11.7.10, Pro Tools 2023.9
Old 02-23-2024, 08:24 AM
MDGenerato MDGenerato is offline
Default Re: Recording vocals with reverb into an SSL 2
Originally Posted by Izzi View Post
Hey All,
Been a while since I recorded any music.
Thanks!
Try creating an Aux channel and sending the reverb into a different channel. That way you can just record the vocals without the reverb recording also.
Old 02-23-2024, 08:33 AM
You misunderstand. in order to use the Monitor Mix on the SSL 2 to avoid latency the vocal track needs to be muted.
Old 02-23-2024, 09:00 AM
thin ice thin ice is offline
Avid have videos to explain basic setups that help you:
https://www.youtube.com/watch?v=p4UnkMlrsLk
Mac Mini M4 24GB
OS 15.4.1
PT 2024.10.2
Old 02-23-2024, 09:31 AM
Yeah, I know how to create effects sends and returns in Pro Tools. What I don't get is if the vocal track is muted in Pro Tools, hence using the Monitor Mix on the SSL 2, then how am I sending that vocal to the reverb aux track?
Here's the video on how to set up the SSL 2 in PT. Doesn't mention anything about adding reverb/effects in a real world scenario.
https://youtu.be/C7WWYsKp4fY?si=JOUOqgexgix_iPwO
Old 02-23-2024, 09:52 AM
sw rec sw rec is offline
“What I don't get is if the vocal track is muted in Pro Tools, hence using the Monitor Mix on the SSL 2, then how am I sending that vocal to the reverb aux track?“
It’ll do that if your send mode is pre-fader. Switch it to post-fader.
Old 02-23-2024, 10:05 AM
What'll do that? And switch what to post-fader?
I think you meant the reverse... switch the reverb send on the vox track to pre-fader (blue)?
Old 02-24-2024, 11:29 AM
Its always been my personal preference to monitor thru Pro Tools and record at a low buffer setting(64) to get plenty low latency. That allows for putting a send on the vocal track to feed an AUX track with a reverb plugin. If you just feel you must work thru the SSL software, might it be possible to ALSO feed the vocal directly to a muted AUX(or AUDIO) track? Doing that would allow you to use a Pre-Fader send to feed an AUX track with a reverb plugin
Recording vocals while monitoring with reverb Pat D. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-29-2016 06:26 AM
Help with Reverb on Vocals Becharax Tips & Tricks 11 09-30-2014 09:00 PM
Reverb on vocals felix822 Post - Surround - Video 7 05-11-2011 06:16 AM
Reverb on vocals 14choirs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 06-25-2008 07:41 AM
Hearing reverb while recording vocals Semantick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-22-2004 06:55 AM
