Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools Sketch
Old 10-21-2023, 07:12 AM
Nick Camaron Nick Camaron is offline
Location: Somewhere in the vicinity of Alpha Centauri, MW
Default Is it true?
Is it true that when dragging a scene from sketch to protools only the raw audio files get copied at 0dB, and not the mix from sketch at all?
Old 10-22-2023, 08:12 PM
take77 take77 is offline
Default Re: Is it true?
I haven't really used Sketch but don't doubt that it might be.
Maybe that's why it's called Sketch & not Mix.
Sorry, I realize that is of little help.
A rough sea makes a smooth sailor.
Pro Tools Studio 2022.7|Windows 10 22H2|Focusrite Scarlett 2i2 (2nd Gen)|Dell Inspiron 3650|Intel i5 6th gen|16GB RAM|Samsung T5 SSD's|Hitachi|Touro HDD
Toontrack EZdrummer 3|Steven Slate Drums 5.5 + Blackbird Studio EX|Spectrasonics Trilian|Native Instruments Guitar Rig 6
Waves|SSL Native|Fabfilter|Softube|Soundtoys|Nomad Factory
Old 10-23-2023, 02:02 AM
Yeah. But thanks for chiming in. But you can Mix in sketch. So it is nonsensical if all that adjusted balance is supposed to be obliterated when doing the step up to PT. Then the Sketch is almost useless
Old 10-24-2023, 07:32 AM
daeron80 daeron80 is offline
If by 0 dB you mean each track comes across at unity gain, then, yes, I think so. I haven't made measurements. But that feels right. Sketch has no automation yet, and the faders are short, so any mix you do in it will be crude, anyway. The whole point of copying tracks to PT is to do be able to add different kinds of tracks, and do a real mix.
Think of it like starting a song on a Tascam Portastudio, printing the track outs to a 2" machine, and continuing the project there.
David J. Finnamore
Old 10-25-2023, 11:35 AM
jwileydrums jwileydrums is offline
Yes this is true, regardless of where the fader is within the Mixer in sketch, when you drag a clip from sketch to the pro tools Edit window it will render any inserts you have to the audio file in sketch but not apply any fader gain or attenuation. Also note that any added reverb or delay added to the track in sketch via the "reverb" or "delay" knobs will not be rendered into the audio file dragged into the pro tools timeline but if reverb or delay is added as an insert to the track it will be rendered when dragged into the pro tools timeline.
Old 11-27-2023, 02:14 AM
As a workaround, you could rename the clip to include the mix level so you have a reference when adjusting fader levels in Pro Tools.
It's an extra step but the focus of Sketch is to get the ideas flowing quickly at basic levels.
That's all I meant when I made the comment about it being called Sketch & not Mix.
I can understand the OP didn't know of this before getting into a mix and was enjoying the creative process.
On the other hand, if the clip maintained the mix level, then you would have to keep the relationship between the clips and normalized faders during the whole final mix process.
This can might make remixing a whole mix or individual subgroups a hassle if you want to keep or remember the relationships between the original levels.
You could create VCA's I suppose.
But you would have more to keep track of and need to calculate things based on how much +/- dB is going on.
Additionally, if you commit a track you could easily forget the actual level you committed at.
Then you have to remember or calculate what 0db on the fader really equals.
Not saying the request to maintain clip levels isn't a valid one.
But until things change just get the clips into Pro Tools once you have your "sketch".
That is, before mixing beyond basic sketch levels.
Could it be true? Finnish 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-27-2005 04:52 AM
Is this true? Yes or No.... dchband 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 06-06-2003 05:07 PM
True 48-Bit Mix Bus Chris Lambrechts Pro Tools TDM Systems (Mac) 1 04-15-2002 02:55 PM
Is this True?? Sudsy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-18-2001 09:49 PM
Is this true? ACIDCHAOS3 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-22-1999 01:41 PM
