Old 09-30-2024, 05:55 AM
Lucasorg Lucasorg is offline
Default Keyboard shortcut - move cursor into time display
Can someone tell me (for Mac and Windows, please) whether there is a keyboard shortcut for placing the cursor in the time display window? I've had a search through the official keyboard shortcuts publication, but can't seem to find what's needed.
For context, I frequently note down times in bigger sessions for particular edit points, then need to look around for alternatives in different takes. Once decided, I enter the time I want to go back to in the display, press ENTER and I'm back exactly where I want to be. A keyboard shortcut would just save time in the longrun!
Thanks in advance.
Adrian
Old 09-30-2024, 06:24 AM
its2loud its2loud is offline
Default Re: Keyboard shortcut - move cursor into time display
It’s the * key on the numeric keypad. If you don’t have a numeric keypad then you can customize your own shortcut in the keyboard shortcuts window. Assuming you’re running at least 2022.4.
Old 09-30-2024, 08:28 AM
smurfyou smurfyou is offline
You can copy and paste the time from there as well. Instead of manually entering it.
(I usually use a temporary marker for this - if you have a numeric keyboard it's quicker - in sequence press period-0-Enter on the numeric to set marker 32000 then period-0-period to recall)
~Will
Old 10-14-2024, 04:56 AM
Thanks for that, and apologies for the late reply. Yes the * works great. I had the BIG COUNTER window open to start with and that became the cursor destination which I didn't notice initially - I was looking in the time window on the main EDIT window...but sure enough, you're right. With the BIG COUNTER closed, it goes where I was expecting.
Thank you!
Old 10-14-2024, 04:58 AM
That's a useful tip too - much appreciated!
Keyboard shortcut to move curser to end of selection? browniespeaks 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 04-29-2022 12:43 PM
Keyboard Shortcut to tab cursor to next grid line? stpete111 Pro Tools 10 13 03-19-2020 12:37 PM
Playback cursor locator keyboard shortcut? SigFriedChicken Pro Tools 12 8 02-18-2018 04:57 PM
Can you move between patches using keyboard shortcut? sponge Pro Tools SE and Essential (Win) 0 08-13-2012 11:43 PM
Keyboard shortcut - Display Mixer mannino Pro Tools M-Powered (Win) 1 08-11-2005 10:28 AM
