linking two 002r, is it possible?
I heard it was possible two cascade two 002r's to get more outputs.
This guy I know said his friend is setup that way, what do you think? He is checking with him to see how he does it. I want to mix out of the box and was wondering what was the best way to get more ouputs. Thanks, Eric M. |
Re: linking two 002r, is it possible?
the only way you can run 2 002r's togehter is with 2 differnt computers and you would
need to use an external clock to sync the 2
www.klarityrecordingstudios.com |
Quad 2.5 G5, 4.5G RAM |
Thats kind of a strange setup, it would be to much trouble.
I might just use what I have and mix out in stems to a mixing console. Thanks, Eric. |
What is the point of 2??? Running out of tracks? Use ACID 5, drag your audio to that and free up tracks if needed. Does not make sense to string 2 together. Go HD if that is the case.
- Doc
MONUMENT SOUND MONUMENT SOUND ON YOUTUBE Monument Sound Facebook "Changing how people hear music one track at a time" |
Read my initial thread, its states I want more ouputs not more tracks.
I want to mix out of the box thats why I want more outputs, cupish? Eric. |
You can get 18 outputs using the ADAT and s/pdif outs and the right outboard gear.
The only way to use two digi interfaces at the same time would be to use two computers.
Paris,
I guess I misunderstood your initial thread "capish." As far as getting more outputs... go get yourself a APOGEE Rosetta 800 and a nice S/PDIF direct box and take full advantage of the 002. Not that I would know anything about that capability? (see gear page on my site below) but hey, just trying to help you some. The Rosetta or any A/D D/A convertor will open doors to that unit so much it is crazy. 18 ins and 18outs. Plenty of I/O for anyone to track a full band, live, or even a small orchestra if you place the mics properly. So with that I hope you will better find the answers that you seek "capish!" For the record: Your initial thread reads "Linking 2 002R, is it possible. And for the other record, I mix with a lot of outboard gear outside the box and that was the main reason why I bought the Rosetta 800. Need to attach A H-3000, Lexicon PCM-90, a few other verbs and FX, Distressors, Compressors, and some other cheesy stuff that makes the sounds I need. Hope this helps.... - Doc
Maybe we will get this in LE 6.8
It would be nice to be able too use two of them on one PC instead of using another ext. converter unit. It would be real nice if the 192 or 96 interfaces worked in standalone mode like the old 888/24 interface did. But this brings a though to mind. I know the LE software might not see or allow you to use 2 interfaces at the same time but, Anyone know if you did connect 2 le interfaces to a computer....would they both work(have power & audio)???? Maybe if they both did power up one one computer..... audio would flow in/out of each unit? The 1st interface would be use as normal and the 2nd would be connected via the adat optical I/O's to the 1st LE unit(similar to using an ext pre/converter, Octopre or Digimax, etc). I think the problem might come with what unit will the Software see as the main interface? If the software somehow would see the 1st unit and bypass the 2nd unit maybe this would work?????? It kight be a long shot, but one can only try. Quote:
Docta'J Download free music at http://www.nukmusic.com nEVER uNDERESTIMATE kNOWLEDGE |
This how I see it:
If LE 6.8 or 7.0 allows 2 interfaces on one computer. those who complaint about BTD. would buy 2 LE units then connect 2 additional converter units (Onyx 800r, Octopre, DigiMax) for a total of 32 I/Os (analog). connect all those to an analog mixing board and do Da do. and others will still BTD like before. WOuld this hurt HD sales? Maybe Would this open up the midrange market Digi is missing? Maybe (maybe with the ability 2 connect 3 leunits) just brainstroming folks..............
SC48 pops when linking or un linking stereo channels | lorenaguey | VENUE Live Sound Systems | 7 | 07-16-2013 09:11 AM |
Linking two 002R | hzd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 04-22-2005 10:38 PM |
Linking 2 002r? | s0nguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 01-23-2004 09:55 AM |
Linking the 001 to 002 | audio1420 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-27-2003 08:38 PM |
Linking 24 mix to HD | Nick Le Mon | Pro Tools TDM Systems (Mac) | 3 | 04-08-2002 02:00 PM |
