Finally!! Tool selection of the exact tool you want!
No longer do I need to waste time or be frustrated by the tools cycling through all the alternative tool selections. For example I can select the Trim tool without needing to cycle past the T/C and loop modes of that tool. No longer do I accidentally start to process audio due to a T/C trim mis clik and need to wait for dialog boxes to stop accidental moves. No longer do I need to go to a menu selection to "flatten" the "looped" region that becomes a completely new type of audio region because I accidentally selected "loop" trim. (the tool that still has NEVER been used in any studio I have ever worked in... yet is selected about 3,000 times a day by mistake)
... Oh.. Wait... Im dreaming... How is this still not dealt with? Yet again, an update for Pro Tools that doesnt include a fix for the MOST ANNOYING DESIGN FLAW IN PROFESSIONAL AUDIO!!! Why... why? UFB |
Re: Finally!! Tool section of the exact tool you want!
A update wont fix accidentally...
I never saw these things as an issue... |
Just don't hit the relevant tool selector if it's already selected!
Pay attention to which tool is selected. |
If you work for film and edit dialogs, you must know how annoying this tool is! It's one of the most buggy things in PT. Only fixing this bug would make me buy PT8.
Michael Goorevich Sound Designer / mixer www.goorevich.com PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3 MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24 |
Its not a bug, just a thing you do not like.
I have edited tons and tons of dialogue and never had a issue with what you describe. That being said, i have of course made the mistake ones or twice.. but not even enough times that i would say its a design "bug" Maybe its you workflow/edit style you should look at ? |
How is it a bug?
A bug is something which either does not work, or does not work how it was intended to. The tool selector does neither of those. |
No multi-tool selected. Why??? It's not intended to work this way. Therefor it's a bug. My workflaw is by using short cuts F5-F8.
It would be nice if you could lock these other tools you don't need. Just like command-click on shuffle-mode.
Or to have in a menu with a right-click... ohwait: that's already working with PT8! Click here for screendump |
Just tested the way you describe it.
At my system Pro Tools HD 8.0.1 it works the way you might expect it to work.. select tool - grab tool - trim tool... i've used the apple F4-3-2 shortcut to enter the tools.. Maybe you wanna update ? |
There is no debating that this is something that needs to be addressed.
Is is possible to change the shortcuts for the Pencil Tool, Grabber Tool, ETC? | jgagne1 | macOS | 2 | 09-24-2013 07:46 AM |
Weird Smart Tool/Selector Tool issue? | Marsdy | Pro Tools TDM Systems (Mac) | 11 | 01-15-2012 07:22 AM |
Get Grabber tool (Object) as part of smart tool? | buckaroo | Pro Tools TDM Systems (Mac) | 8 | 07-13-2010 04:21 AM |
Pencil tool turns into mouse pointer tool when drawing | arvid.lind | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-11-2010 12:36 AM |
Smart Tool / Pencil Tool in Midi Editor | AndyJCP | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 04-26-2009 08:08 PM |
