Old 02-17-2021, 01:16 PM
K Roche's Avatar
K Roche K Roche is offline
Default Re: How can I change the default track routing ?
This is a bug, I think.
I have thought about this, as I would like my new tracks to default to an internal bus, but I never got around to exploring it.
Anyway, I just found that after setting "default bus output" in I/O busses page, even if it still says "Output 1-2", any new tracks I create will output to a bus. Not the bus I wanted, on first try, but it seems it is possible, though the I/O setup defalt will always say "Output 1-2".
Yes and no. I just messed around with it based on your post
Here is what I found. First it did in fact output to the new bus I wanted on new tracks
So this is what I did ::::
When I opened a new blank session and opened Setup > I/O > Bus tab
#1 I could select a different bus as the Default Output Bus. and Yes it would not change in the selection box (right then ) And I had to do this in both the mono and stereo parts of Default Output Bus button, and would see the check mark next to that new new bus .
#2 any new tracks added to the session were routed to the new selected (desired ) bus.
#3 when I closed the session and reopened ,,, it would then show the new (desired) output bus as the Default Output bus AND when I created an entire new session, It was also showing as the new bus.
System :
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2023.12.1 Sonoma 14.4
Enjoy the Journey
.... Kev...
Old 02-17-2021, 01:24 PM
Ben Jenssen's Avatar
OK, I tried a little more, and it works.
In the I/O setup, bus tab, set the Default Output Bus to whatever internal bus you want (two times, one for audio and one for stereo), they will be marked with a bullet in the list, but the Default Output Bus will not necessarily show the change. This is the bug. But the new tracks you create will default to the internal bus you selected.
Old 02-17-2021, 01:45 PM
K Roche's Avatar
I assume you mean one for (mono) and one for stereo ?
Also I (may) have discovered something else so I went in some old sessions and found ::
If I selected the (stereo) selection first, it would not change in the box BUT If I selected the new Bus in the "mono" selection first, it instantly changes in the Default Output bus box, and also even If I selected Stereo first as soon as I selected mono also it would instantly change
System :
Enjoy the Journey
.... Kev...
Old 02-17-2021, 02:22 PM
Of course. Mistake.
Anyway, it looks like here that new tracks follow the setting I made.
Old 02-18-2021, 04:16 AM
Talisker Talisker is offline
In my case, If I open the folder "default output", I can see, that the right bus is checked. However it still says "Monitor" and also new tracks default to "Monitor".
Anyway not a big deal looks like I have to get the routing into my muscle memory when creating new tracks.
Mac Mini M1, 16 GB Ram, OSX 10.181.1,Focusrite Scarlett 18i20,Behringer ADA 8200,Pro Tools 2022 2xGlyph hard drive 750GB
Old 02-18-2021, 04:46 AM
ChuckS ChuckS is offline
Forget about the checked stuff. Lower right on the Bus tab in I/O Setup - Default Output Bus - set the mono and stereo paths to the bus you use for the aux. It always helps if you name your buses.
PT 2024.3 DP 11.31 VEP 7.x with various VIs
NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11
MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11
MOTU M4 on MacBook Air M2 2023 Sonoma.4.1
Old 02-18-2021, 05:09 AM
But that is exactly what I did....did not work
Old 02-18-2021, 05:16 AM
Don't know what to tell you then. I have everything routed to an aux via a bus named SubMaster. I have the I/O Setup Default Output Bus mono and stereo set to SubMaster and every new track I create defaults to output SubMaster. So it works fine here. I think that is the workflow you're going for - output everything to aux and then route the SubMaster to the master fader.
Old 02-18-2021, 09:48 AM
K Roche's Avatar
Humm I am wondering if inaccurate communication is not creating some problem ?
Perhaps screen shots and or a screen recoding can clear things better ?
For example what does "open the folder default output", mean ?
Because to my knowledge there is no "folder" default output" ?
There is
In Setup > I/O the "Bus" tab which opens up the Bus matrix window
In the lower right of that window there is the "Default Output Bus" button, with dropdown window where you can choose the "Default Output Bus.
Here is a quick screen recording of changing "Default Output Bus
https://youtu.be/dZLlIqk6Dsg
System :
Enjoy the Journey
.... Kev...
Old 02-18-2021, 11:38 AM
musicman691 musicman691 is online now
Problem is it's only on a per-session basis. Doesn't carry over to another or new session.
Basic Routing Folder Default Jkoebe Pro Tools 2020 19 02-08-2021 08:17 AM
Change default track height? itsjustmeee123 Pro Tools 2020 1 04-07-2020 07:46 AM
Change Default Track View Mode migueldgoncalves Pro Tools 2018 2 01-15-2019 09:30 AM
HELP! Is there a preference in PT to change default IO subpath routing creation? bassmagnetic Post - Surround - Video 1 08-09-2017 04:03 PM
Can I change the default output on a new track? jrs320 Pro Tools TDM Systems (Mac) 2 10-23-2005 07:10 PM
