Old 11-07-2024, 07:43 AM
littlesicily littlesicily is offline
Default OS 15.1 w/ PT 2024.10 SLOW menu clicks
I was previously on Ventura and PT 2024.10 and this was fine, but now on Sequoia 15.1 w/ PT 2024.10 it is dreadfully slow when trying to insert a plug, right-click on a track to open the dropdown, etc.
It delays close to 1sec every time when it was super fast on Ventura.
Is this a known-bug?
Btw, I did a clean install on my Mac Studio M2, installed all apps and plugs from new downloads, not migration assistant.
PT 2024.10, Mac Studio Max M2 64GB RAM, OSX 15.1
Old 11-07-2024, 05:53 PM
sw rec sw rec is offline
Default Re: OS 15.1 w/ PT 2024.10 SLOW menu clicks
Odd. I quite accidentally (long story) got bumped up to Sequoia 15.1, already had 2024.10 in place, did NOT do a “wipe & start over,” against common recommendations. Just an in-place upgrade. (Did not MIGRATE anything.) And everything I’ve thrown at it works just fine. What I have noticed is that my Izotope RX11 instances are a little laggy, but to be fair, they advised against going to Sequoia in the first place. They still work, but the GUI isn’t as snappy. That’s the only thing I’ve noticed. M1 Studio Max, Apollo 8. Just did 15 projects, everything from bare bones radio spots to full on post for video. Everything’s fine.
Old 11-07-2024, 06:21 PM
I actually tried using migration assistant and had the same issue. So I then wiped the system drive and started over.
Old 11-07-2024, 10:14 PM
Is it on EVERY plugin, or some in particular? Not all of them have been qualified for Sequoia yet (ex: aforementioned Izotope plugins, but they still work. Just a smidge laggy.)
2024.6 VERY laggy and slow.. WAD Windows 5 10-14-2024 02:21 PM
2024.3.1 bugs - Calculating wavecache is very slow foret_sombre macOS 4 06-26-2024 12:27 AM
MidiOutput selector Menu opens slow since 9.0.5 Hanswurstlsepp Pro Tools TDM Systems (Mac) 48 04-11-2012 06:51 PM
Menu BUG...Menu FREEZES...Menu LOCKS UP...Restart Pro Tools! a2zproductions Pro Tools TDM Systems (Mac) 16 05-08-2008 08:30 AM
slow menu response euphjazz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-22-2004 09:28 PM
