Old 08-28-2024, 03:17 PM
ralphonz ralphonz is offline
Default EuControl 23.11 crashes Logic Pro 11.0.1 on startup
Hi all,
Appologies if this is in the wrong pace, I couldn't find a EuControl forum.
It's been a very long day! I've needed to load some projects in Logic Pro only to discover it crashes as soon as it tries to open a window after starting up.
It's taken me all day to figure out that EuControl is the culprit. Removing EuControl from my system (using the unified installer) is the only thing that allows logic to open again as normal (all projects and plugins working).
I re-installed Eucon and the problem came back immediately.
Logic gives me the same crash report every time:
Code:
Process:               Logic Pro X [10477]
Path:                  /Applications/Logic Pro X.app/Contents/MacOS/Logic Pro X
Identifier:            com.apple.logic10
Version:               11.0.1 (6029)
Build Info:            MALogic-6029000000000000~2 (1A98)
App Item ID:           634148309
App External ID:       865964375
Code Type:             X86-64 (Native)
Parent Process:        launchd [1]
User ID:               501
Date/Time:             2024-08-28 22:14:29.1475 +0100
OS Version:            macOS 14.6.1 (23G93)
Report Version:        12
Anonymous UUID:        3F216801-2683-A1C0-8BFC-344170B5806D
Time Awake Since Boot: 630 seconds
System Integrity Protection: enabled
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       KERN_INVALID_ADDRESS at 0x0000000000000000
Exception Codes:       0x0000000000000001, 0x0000000000000000
Termination Reason:    Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process:   exc handler [10477]
VM Region Info: 0 is not in any region.  Bytes before following region: 4466987008
      REGION TYPE                    START - END         [ VSIZE] PRT/MAX SHRMOD  REGION DETAIL
      UNUSED SPACE AT START
      __TEXT                      10a40d000-10c7d1000    [ 35.8M] r-x/r-x SM=COW  /Applications/Logic Pro X.app/Contents/MacOS/Logic Pro X
Kernel Triage:
VM - (arg = 0x3) mach_vm_allocate_kernel failed within call to vm_map_enter
Thread 0 Crashed::  Dispatch queue: com.apple.main-thread
0   Logic Pro X                   	       0x10b13140d 0x10a40d000 + 13779981
1   Logic Pro X                   	       0x10ae8b4f1 0x10a40d000 + 11003121
2   Logic Pro X                   	       0x10ae25adf 0x10a40d000 + 10586847
3   Logic Pro X                   	       0x10a8cb3dc 0x10a40d000 + 4973532
4   Logic Pro X                   	       0x10bc5eae4 0x10a40d000 + 25500388
5   Logic Pro X                   	       0x10afc0caa 0x10a40d000 + 12270762
6   Foundation                    	    0x7ff809bbd7c4 __NSFireTimer + 67
7   CoreFoundation                	    0x7ff808be944c __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 20
8   CoreFoundation                	    0x7ff808be8ffa __CFRunLoopDoTimer + 785
9   CoreFoundation                	    0x7ff808be8c36 __CFRunLoopDoTimers + 285
10  CoreFoundation                	    0x7ff808bccf12 __CFRunLoopRun + 2104
11  CoreFoundation                	    0x7ff808bcc112 CFRunLoopRunSpecific + 557
12  HIToolbox                     	    0x7ff8135eba09 RunCurrentEventLoopInMode + 292
13  HIToolbox                     	    0x7ff8135eb816 ReceiveNextEventCommon + 665
14  HIToolbox                     	    0x7ff8135eb561 _BlockUntilNextEventMatchingListInModeWithFilter + 66
15  AppKit                        	    0x7ff80c23c171 _DPSNextEvent + 880
16  AppKit                        	    0x7ff80cb50af0 -[NSApplication(NSEventRouting) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1273
17  Logic Pro X                   	       0x10bc6c09d 0x10a40d000 + 25555101
18  AppKit                        	    0x7ff80c22d585 -[NSApplication run] + 603
19  AppKit                        	    0x7ff80c2014f3 NSApplicationMain + 816
20  Logic Pro X                   	       0x10af4d6d3 0x10a40d000 + 11798227
21  dyld                          	    0x7ff808765345 start + 1909
There is more but I think this is the relevant part.
I only recently got an S1 and Dock to replace an SSL UF8, and couldn't be happier with them in Pro Tools. However, Logic now won't load at all!
Old 08-28-2024, 05:33 PM
Default Re: EuControl 23.11 crashes Logic Pro 11.0.1 on startup
Appologies, wrong forum after all. Mods can you move this thread? Or delete and I will re-post.
Old 08-29-2024, 03:50 AM
I have tracked this down specifically to one file. If I remove it to my desktop I can at least open logic and then move it back when I'm working in Pro Tools.
The file in question is /usr/local/lib/libEuCon2.dylib
Needless to say, Eucon isn't working in logic if I remove this file - but that is the only way I can open Logic.
EuControl app doesn't have to be running. The very presence of this file prevents logic from working.
Old 08-30-2024, 02:06 PM
EddieJones's Avatar
EddieJones EddieJones is online now
This is the correct forum. This is a known issue that requires a fix on both our side (EUCON) and Apple's (Logic). We have made our fix, and it will be in EUCON 24.10. We have sent all the details to Apple about their bit and they are generally good at jumping on it.
Note, the fix we did clears this up 90% already for EuControl. (not so much for S6 unfortunately)
Old 09-01-2024, 12:23 PM
Amazing! Great to know you (and apple) are on the case! Only a month or so of moving that file around - it's much more bearable when you know when it's going to be fixed
Old 11-08-2024, 01:53 AM
Unfortunately, the EUCON 2024.10 update hasn't fixed this issue. I still can't open a Logic 11 project unless I move /usr/local/lib/libEuCon2.dylib to a different location.
I suppose I'll have to wait for a fix from apple.
Old 11-08-2024, 08:49 AM
EddieJones's Avatar
Many others have reported this fixed including beta testers. I wonder if you have a bad install. Using the installer check remove all apps and remove all prefs, reboot and reinstall. Make sure Logic is the latest update. If it still does this, can you create a new blank session, not from a template and see if thats OK.
Old 11-14-2024, 02:49 AM
Thanks Eddie, I finally got this working. Eucon is now working great with Logic Pro!
In case it helps anyone else: Reinstall didn't work. I did some digging in the crash log and tested everything on my MacBook (not my main studio computer). Looks like my Hackingtosh needed an ethernet driver so I installed IntelMausi.kext and now everything is working great.
Eucontrol crashes Logic Pro Je suis Avid S1, S3, Dock and Control App 6 08-30-2024 02:07 PM
Eucontrol crashes logic when changing focus window mikaels_ Avid S1, S3, Dock and Control App 4 11-01-2022 06:08 PM
EuControl Slow Startup 10.10.5 Big Mother Artist Series 20 05-19-2016 09:06 AM
Does S6 install Eucon/Eucontrol ? Logic crashes... vudoo Avid S4/S6 5 05-03-2016 11:46 AM
EuControl crashing Logic Pro 9 on startup T S Artist Series 1 07-12-2012 01:52 AM
