Mix24 + on G5
Digidesign claims that the mix 24 system won't work on Mac G5. I have just prchased a Mix system. I wonder if anyone out there have tried the mix system on a G5 and made it work out?? Regards! |
Re: Mix24 + on G5
You may want to read the following threads:
New Powermac G5/Mix plus compatability Entry level G5 with a MIX system Who is using MIX on a G5? Power Mac G5 1.8's with Mix hardware? Mix on a G5? Mix Plus & G5: right size/voltage but no support?! Mix on a Magma/G5 does NOT work Mix Plus on a G5? Using TDM Mix Plus System on G5 w/Panther G5 / Expansion chassis / DSP farms Mix Core and G5 G5 & MixCore - Anyone running this Config? MIX CORE & G5 TDM on G5 G5 & Mix+ MIX on G5 Even more important than all of these threads, is this statement from Digidesign. If you are not working in post, buy the Dual 1.42GHz G4. If you are working in post, buy the Dual 1.25GHz G4. If you already own a G5, try to sell back the MIX system.
Re: Mix24 + on G5
Links seem to do not work,
any reason why ? Quote:
Re: Mix24 + on G5
maby bcs they are two decades old?
Re: Mix24 + on G5
So still there just to accumulate garbage ?
Re: Mix24 + on G5
Internet is full of garbage in case you haven't noticed.
To the point, when PT was rebranded from DigiDesign PT to Avid PT (v9) the website was redone. Whatever says digidesign.com is pointing to the old website.
this ? is for both mix24 5.1 and le 6.4 | everydayradio | Pro Tools TDM Systems (Mac) | 1 | 09-29-2006 09:39 AM |
DAE MIX24 with OSX | Kokoa | Pro Tools TDM Systems (Mac) | 1 | 03-17-2005 09:42 PM |
MIX24 888 AND NUENDO | detroitkruk | Pro Tools TDM Systems (Mac) | 7 | 11-25-2004 01:08 PM |
New G4 or G5 for new PT Mix24 System | rope | Pro Tools TDM Systems (Mac) | 14 | 01-05-2004 11:39 PM |
6.2 MIX24 on G4 - When? | jimlongo | Pro Tools TDM Systems (Mac) | 7 | 12-22-2003 04:08 PM |
