Old 10-29-2024, 10:01 AM
Benny Mouthon's Avatar
Benny Mouthon Benny Mouthon is offline
Default "AUTOMATION too dense" error 20021 w/ 2024.10
started getting this this morning: 52 minute mix w/ video, episode 3 of 4 so I made a clean session from ep. 1 (=eps. 1+2 went fine, was running PT Ultimate 2024.06), but after updating to 2024.10 I'm getting this about 1/2 dozen times this morning.
Not a very dense mix yet, FabFilter Pro3 mostly, some altiverb 7 instances, nothing too crazy (in Rosetta mode), on a Mac Studio 64gB ram.
Bug ??
Old 10-29-2024, 10:54 AM
marianna's Avatar
marianna marianna is offline
Default Re: "AUTOMATION too dense" error 20021 w/ 2024.10
Bug ??
This use to happen back in the day - from what I can gather, 20021 is strictly related to plug-ins, and we've had reports of it happening on other systems using outdated versions of Penteo or Relayer hence why it is suggested to update them if you have them (or remove them temporarily). Since the error in question is related to plug-ins, it would be worth to make sure all of your plug-ins are up-to-date.
Please capture *only* the most recent ".dlog" file generated after seeing the error, and send it to me for evaluation. my email is below....
See: http://avid.force.com/pkb/articles/e...o-Tools-System
Thanks Benny!!!!
Marianna
Marianna Montague
Sr. Dir. CX and Community | Customer Advocate
[email protected]
cell +1 (813) 493-6800
AOL IM avidmarianna
Twitter Avidmarianna
We're Avid. Learn more at www.avid.com
Old 10-29-2024, 07:22 PM
Thanks Marianna. I ended up going back to 2024.6 and...not a single issue all day (same mix), it clearly points to some kind of issue w/ .10
Also, I updated all my plugins last week; latest version of WAVES (everything..), Altiverb 7, Speakerphone, Isotope RX 9, McDSP SA2 and
FabFilter Pro Q3, that's pretty much it !
Old 10-30-2024, 07:46 AM
marianna's Avatar
Benny - thanks for this info. Are you adverse to me creating a case and working on this for you?
ANYONE else who has this report in ASAP and please please save a error log so we can get to the bottom of it.
Marianna
Marianna Montague
[email protected]
AOL IM avidmarianna
Old 11-01-2024, 10:24 AM
Marianna
Sure thing, happy to help but I'm on a mix, finishing Tuesday or Wednesday so..not installing anything before then
Old 11-06-2024, 06:46 AM
DerekCamacho DerekCamacho is offline
Thanks Benny!!!!
Marianna
Thank you so much for the article link, you saved my day.
Old 11-06-2024, 08:43 AM
marianna's Avatar
Happy to help.... love this community!!!!!!!!
Marianna
Marianna Montague
[email protected]
AOL IM avidmarianna
Old 11-07-2024, 12:59 PM
lucienpalmer lucienpalmer is online now
I've been getting tons of these with with he release version (and beta). When it happens, I can't work anymore and PT throws up the error every time I hit play. Restarting the session or Pro Tools is the only solution.
Marianna- I'll email you my log right now.
Pro Tools Ultimate, HDX3 & MTRX + HD MADI
7,1 MacPro, 3.2GHz 16-core, OSX 10.15
S6 M40 48-5, panners, MPM,Dolby Atmos RMU
AJA Kona 4k, Sync HD
www.ToolshedAudioPost.com
www.TheToolshedStudio.com
Certified for Dolby Atmos Home Entertainment
Old 11-08-2024, 05:46 AM
This error has been around for years (at least 6 or 7 Years). Only way out is to re-launch the session. Plenty of old threads about it with no real solution...
I opened a case 4-5 years ago but it was closed without a solution. My strong suspect is AVID channel.strip and since I've abandoned it I have not seen the error in the last year.
Maybe try the workarounds discussed before:
https://duc.avid.com/showthread.php?...ighlight=20021
PTHDnPCIe 2024.10.1 (OSX14.7), 8x8x8, MacPro 14,8, Decklink SDI 4k, SYNC HD, Nanosyncs HD, 64GB RAM, Xilica Neutrino, Meyersound Acheron
Old 11-10-2024, 08:05 AM
Rolling back to 2024.6 made it go away for me.
I’m pretty sure I’m not using Channel Strip anymore. It’s possible I still have a few on uneven returns. I’ll have to check through my session and test 2024.10 without them.
Automation "Learn" feature - e.g "Space" plugin Zoduati Pro Tools 12 1 05-23-2016 08:46 AM
Alt-Shortcut to reach "Edit" > "Automation" > joachim Windows 0 10-13-2014 09:14 AM
Pro tools 9 crashes at startup "Bus error" in thread "MainThread", at address 0x0 danball macOS 2 09-26-2011 05:49 PM
"Audio too Dense" problem - Are these possible solutions? Sparky1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 19 12-07-2002 11:05 PM
playback error -9121 "audio too dense" Joseph Anderson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-11-2002 11:01 AM
