  #21
Old 11-01-2024, 10:09 AM
digiot digiot is offline
Default Re: Sequoia !?
Ugh of course UA is not yet compatible with Sequoia
Both for Spark and UA Apollo/Satalite
So I'm going to hold of on the update.
  #22
Old 11-02-2024, 04:55 PM
sw rec sw rec is offline
I thought I was updating from Ventura to Sonoma, but it bumped me up to Sequoia. Apollo 8 TB2, Volt, and pci-e and satellite OCTOs all working fine.
Whew. If I would have had a choice, I would have chosen Sonoma, but I seem to have lucked out so far.
  #23
Old 11-05-2024, 03:27 PM
K Roche's Avatar
K Roche K Roche is offline
Originally Posted by MCorbin View Post
Great question Kev
Yes, since 24.10 is the first version of Pro Tools that is qualified on Sequoia, then by proxy yes, Carbon is qualified for Sequoia with 24.10.
While there was not much/if any specific fixes in Pro Tools to support Carbon on Sequoia, there were many fixes in Pro Tools itself to perform well on Sequoia.
So yes, Carbon and PT 24.10 are like peanut butter n jelly on Sequoia bread.
m
So when I went install 24.10 on my studio machine (intel iMac ) On OS Ventura 13.6.1
The installation was successful
BUT I got a ghosted out message that said PT Carbon device cannot connect ?? and Carbon was not listed in the choices for audio device. (Which hadn't happened in previous PT version updates) so I did as the message indicated went to Audio Midi selected Carbon But even after 30 seconds Carbon was still not listed in Playback device window.
So I ended up choosing I think iPhone mic > launched PT then was able to select Carbon and then finally it said Carbon needed a firmware update ( which always happened before when you first launched PT ) just a heads up Am playing with now to see how it runs so far so good ---other than that circuitous route to get Carbon as the audio device
Here is the dialog I got
System :
Studio - Avid Carbon interface , PT Ultimate 2024.10.1 Mid 2020 (intel) iMac 27" OS Sequoia 15.1.1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.10 --Sequoia 15.1
Enjoy the Journey
.... Kev...
  #24
Old 11-06-2024, 05:08 AM
creativecontrol's Avatar
I believe that behavior is documented here in the known issues:
Pro Tools cannot detect Carbon during the first launch of Pro Tools after being installed on Sequoia, but is visible in the Playback Engine after the initial launch.
https://avidtech.my.salesforce-sites...a-Known-Issues
I'll take a look at it here as well on a 15.1 system.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #25
Old 11-07-2024, 03:50 PM
K Roche's Avatar
best,
Jeff
Humm Ok so just I understand I do an initial launch and then just close PT and then Launch again and then select it in the playback engine ? good to know when I do upgrade to Sequoia..
So can we then assume It is a PT 2024.10 issue ? because it also happened when as I said I upgraded to PT 2024.10 but am still on Ventura 13.6.1 ?
System :
Enjoy the Journey
.... Kev...
  #26
Old 11-07-2024, 04:43 PM
Well, I just tested this on a M1 Mac mini that I recently updated to macOS 15.1 - just put PT 24.10 on it and launched and no issues. It is a bit of a Frankenstein machine - as I have HDX, RME HDSPe, and now additionally Carbon on it. I had to pivot from HDX engine and relaunch with Carbon - but all of the inputs and outputs are fine. Sonnet Thunderbolt AVB adapter.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #27
Old 11-16-2024, 09:32 AM
infohou infohou is offline
So 15.1 did not help Carbon Central?
Y'all hang in there,
Robert
Robert A. Ober
IT Consultant, Vidcaster, & Freelance Preditor(Producer/Editor)
Houston, TX
  #28
Old 11-16-2024, 01:24 PM
From the Carbon Support Base:
https://avidtech.my.salesforce-sites...n-Requirements
Carbon with AMS.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #29
Old 11-16-2024, 05:08 PM
Carbon with AMS.
best,
Jeff
Thanks, but maybe next time just say No.
Robert A. Ober
Houston, TX
  #30
Old 11-16-2024, 06:05 PM
Apologies, I thought that was communicated in Mark's post + the referenced KBase. We are hoping that macOS 15.2 brings back full Carbon Central support.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
MacOS Sequoia? Paul Alvarez macOS 23 10-14-2024 12:49 PM
macOS Sequoia (15.x) - Not qualified yet marianna Pro Tools 7 10-06-2024 10:07 AM
MC Transport and Sequoia TechSpec Artist Series 3 01-17-2012 01:44 PM
Samplitude/sequoia 11 is MBOX 1 compatible? DjRybe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-29-2009 05:34 PM
Sequoia vs. Samplitude... Ralph K 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-22-2004 10:58 AM
