Old 09-21-2009, 08:16 PM
shanabit shanabit is offline
Default ADC Lesson
Hey guys, Im going to tackle learning my way around this issue so I can use my Protools LE 8 more often.
1. TRACKS= Shift them back by the delay shown a the bottom of the track
2. BUSSES ??
3. AUX SENDS ??
4. Master buss?
Etc
I DONT want to use any of the time adjusters if I dont have to. I want to manually learn how to do this first
Thanks
MacPro 8 Core,2.4, 14 Gig Ram.
OSX 10.8.2
Old 09-21-2009, 08:28 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Default Re: ADC Lesson
What plugs are u using... I mean, I realllly do not ever have a problem with latency...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 09-21-2009, 08:52 PM
WAVES Gold, Musicians Bundles and the stock DIGI stuff.
I just need to know how here in case I do if you know what I mean
OSX 10.8.2
Old 09-21-2009, 08:55 PM
I gotcha'... Well yeah, duplicate the track, & shift as needed... U can hit alt+H to shift...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Old 09-22-2009, 06:40 PM
WHat about number 2,3,and 4?
OSX 10.8.2
Old 09-22-2009, 07:40 PM
flommer flommer is offline
2. BUSSES ??
3. AUX SENDS ??
4. Master buss?
Etc
Thanks
Why don't you want to use time adjuster?
Using time adjuster IS the manual way to do it..
If you were going to adjust everything just by shifting, then I would think you would have to wait until you have ALL your plugs, tracks, auxes, decided. Then figure everything out. Then, when you decide you need to change a plug somewhere you're screwed, because you don't know where everything WAS..
So here is the way to do it using time adjuster...
http://www.screencast.com/users/peed...ders/tutorials
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 09-22-2009, 07:57 PM
getz76 getz76 is offline
Nudging is a bad idea.
As flommer said, change a plug-in and you are screwed. Change your playback engine and you could be screwed, too.
Time Adjuster is manual.
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 |
| Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 |
Old 09-22-2009, 08:02 PM
A little experimentation will show you which plugins cause latency. Many of them do not. I have used PT for 5 years and almost never have any issues with latency. I leave plugins off the master(I do that as a separate step in a separate session or in WaveLab). The worst plugins will be anything that is "look ahead" like any mastering/brickwall limiter or a gate that claims zero attack time. I use buss compression with drums(parallel compression) with BF76 and Waves SSL buss compressor all the time with zero phasing issue.
Old 09-23-2009, 01:17 AM
tamasdragon tamasdragon is offline
Or buy mellowmuse ata. With a little settin' up, it will do it for you.
TD
my blog:Tamas Dragon
Old 09-23-2009, 08:42 AM
^^^yeahppp^^^
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Just learned another new, expensive lesson Pred80r Pro Tools TDM Systems (Mac) 11 12-30-2009 10:40 AM
Let this be a lesson to you kids out there! Wango 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 10-04-2009 06:12 AM
A lesson learned from the pro's at DUC randyT 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-04-2005 09:21 AM
Latency lesson needed? AudioArtCafe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-09-2004 07:48 AM
balanced, unbalanced -- I need a lesson Joseph Grimm Tips & Tricks 2 04-30-2001 02:23 AM
