Old 03-21-2018, 04:08 PM
cesarjperez cesarjperez is offline
Default Mixing Window, AutoMatch Indicator, can't change track volume....
I don't know how this indicator turned on, I've done research on it and looked it up in the Pro Tools Help menu, but nothing explains why the AutoMatch Indicator turns on or how to turn it off.
If anyone has some more information on this contact me ASAP because this has happened several times, where I have to restart a new session because a couple tracks will revert to the volume the AutoMatch Indicator was activated.
Old 03-21-2018, 04:29 PM
BScout BScout is offline
Default Re: Mixing Window, AutoMatch Indicator, can't change track volume....
It's always "on." It's just an indicator for what you've done -- it doesn't do anything but tell you that things don't match.
It means you have volume automation on the track that differs from where your current fader is. Either delete the volume automation from the track or put the automation on the track from "read"/"auto read" to "off".
Old 10-13-2022, 08:56 AM
EVaschon EVaschon is offline
I had this exact same problem. For some odd reason, the volume fader on a particular track seemed to have a mind of it's own and get stuck on a certain volume level. When I would turn it up, it would pull itself back down and when it turned it down, it would pull itself back up. Even when I clicked "all" I was able to turn all tracks down but this one. I didn't do anything manually to change the volume level of this track so I had no idea why it started acting this way.
Ultimately, I clicked onto [audio volume] and then grabbed the audio line and moved it up and down randomly. Then I put it back to position "0". Strangely enough, that stopped it from wacking out on me and I haven't had anymore trouble with it.
Perhaps that will work for you as well.
Old 10-13-2022, 12:58 PM
its2loud its2loud is offline
This is called automation and is written data on the track. Depending on the Automation Mode you are in, the fader will act differently. My suggestion is you do some reading on the different types of automation and modes offered in Pro Tools or watch some tutorials on volume automation
Old 08-23-2023, 07:02 AM
kidbazooka kidbazooka is offline
I am having the same issue. I might have a track with some simple automation written, let's just say a few volume increases and decreases, but as soon as I launch the session the arrow down AutoMatch is stuck on and the fade is out of position all the way down. In other words the session does not load with the volume fader in the correct position on a track that might have a simple volume automation applied to it. The arrow down light is on and does not change when the animation is supposed to, as the track progresses once play is activated. I can make the automation inactive and that doesn't help. I might move the fader and expect the fader to return to the correct position, but that doesn't help. The volume fade is just stuck, or returns to the bottom position as soon as I let go of the fader. I'm not in the process of writing animation, and none of the animation settings appear out of place. In fact, any animation I do is typically with a mouse, just drawing an increase or decrease as needed, with as few inflection points as needed. And this didn't just start happening. I've been plagued with this issue for years, through many version updates. Usually restarting Protools clears out the few tracks that might be affected with this AutoMatch ghost in the machine. I've recently found that the arrows were called AutoMatch and now have the small Automation window open and to the side. By hitting SUSPEND and the reactivating, the highlighted AutoMatch arrows disappear and my faders all function as expected. Does anyone know what might be causing this? I'm trying to figure out if the name AutoMatch would give me a clue as to what is going on - what is being matched? Can anyone offer some advice or help?
Hrdw: Mac Studio, Lynx Aurora (n) 24 in 4 out, Sonnet enclosure with 2 UAD2 PCIe cards, Glyph NVMe SSD Drives
Old 08-23-2023, 07:14 AM
Read post #2 and check what automation mode your track is in.
Old 08-23-2023, 09:39 AM
It's may be automation, but it is not functioning correctly. I open a session and the fader is now locked in the down far down position, but if I restart Protools the same fader maybe "free" but another is locked down? No, something is not functioning correctly.
How come I can't change the volume in the mix window? sb_stefan Pro Tools 10 9 01-28-2020 05:19 PM
Can't Mute or Change Volume on Audio Track and Instrument track FunkTools 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-10-2010 04:40 AM
change gain, but volume indicator doesn't move. hitwriter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-28-2005 08:05 PM
change gain, but volume indicator doesn't move. hitwriter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-28-2005 07:47 PM
I pan the MIDI track and get volume change- Paul Cavins 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-30-2003 04:03 PM
