PT 12.8 ObjectGrabber doesn't work with MIDI Regions
I remarked today an error, that you can't "grab" MIDI Regions with the ObjectGrabber. if you select them yellow outlined and try to move them, it's not possible... if there's an AUDIO File included, it works like all the years before... Can someone confirm that on another System??? Best Chris |
Re: PT 12.8 ObjectGrabber doesn't work with MIDI Regions
Hi, I'm on 12.8.1 and it works fine. Pretty sure it was fine for me with 12.8...
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
12.8.1..???
No one else that problem with MIDI Objects in case of the ObjectGrabber??
Hey there,
I posted a query about the object grabber recently: http://duc.avid.com/showthread.php?p...25#post2442825 Hardly any response. It surely can't just be us two. I find that Shift and Click works for non-contiguous, or random, notes in the MIDI editor but I am unable to select random CLIPS in the main edit window with the Object Grabber... it selects whole blocks of clips instead just like the normal grabber. Anyone any suggestions? We're all ears gang...
Laurence J Blackler Producer, Composer, Session Musician, Vocalist, Lyricist http://ljblackler.com PC : Processor Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz 4.00GZ Motherboad Sabertooth Z97(mark 1) RAM 16.0 GB C Drive - Crucial MX100 256GB SSD Samsung 850 EVO 500GB SSD External - Samsung 850 EVO 500GB SSD NVIDIA GeForce GT 610 - 6 monitor support. NVIDIA High Definition Audio , ASUS Realtek HD Audio Manager (Windows 10) Pro Tools newest (not HD) |
works fine here ... not sure why you are having issues ... toss your prefs maybe !!!
Have also 12.6.1 on the computer... After trashed prefs etc, tried it unter 12.6.1, everything fine... Back on 12.8. same problem again...if you grab MIDI Files and f.e. 1 audio File, it works... just with MIDI no way... |
just midi Clips: 1) select Object Grabber 2) select 1st midi Clip 3) hold Shift key and select 2nd midi Clip 4) let go of shift key, move both midi Clips, you see Yellow Border - Works audio and midi Clips: 5) select midi Clip 6) hold Shift key and select audio Clip 7) let go of shift key, and hold Command key and move both Clips - Works where am i going wrong that i cannot reproduce your fndings ???? cheers john
I try to make it clearer now: Just MIDI Clips 1) select Object Grabber 2) select 1st MIDI Clip (dragging the ribbon over it by clicking Mouse, hold move over the region, let mouse go) 3) select 2nd MIDI Clip with shift key (dragging the ribbon over it by clicking Mouse, hold move over the region, let mouse go) Both regions have yellow border.. Try to move, only the 2nd clip is moved, still having the yellow border, 1st region looses border, stays at it’s position Other example: 1) select Object Grabber 2) select 1st MIDI Clip (clicking onto it) has NO yellow border!!! 3) select 2nd MIDI Clip with shift key (clicking onto it) as NO yellow border!!!, instead the whole area between the two clips is marked like done with TimeGrabber… I did record also a small screenshot movie, here's the link: https://wetransfer.com/downloads/7d9...3195206/13928d Best Chris Last edited by ChrisSimon; 08-13-2017 at 12:53 PM. Reason: more details |
alt drag copy audio regions doesn't work, why? | damasio | Getting Started | 3 | 09-30-2014 07:38 PM |
Moving regions with fade on the whole region doesn't work | focusonsound | Pro Tools 11 | 0 | 08-25-2014 02:53 AM |
MIDI doesn't work!!?!!! | meyoik | MIDI | 1 | 04-25-2010 02:30 PM |
why doesn't "control/click" work on midi regions? | tunespin | MIDI | 2 | 11-19-2009 08:09 PM |
Tab doesn't work in auto rename regions | Inaam | Pro Tools TDM Systems (Mac) | 0 | 10-20-2005 04:46 PM |
