Unable To Uninstall PT Le 6.9. Win XP Pro
Hi!
Yesterday I Tried to install PT Le 7.0. It required uninstallation of Pt Le 6.9. The problem was,that when the Unistallation procedure began, I checked the remove tick box but it didn´t complete the action. Next I tried Manual removal ( removed the digidesign folder with it´s contents etc....) but the 6.9. still shows in control panel add/remove section and what´s worse,I can´t re-install the damn thing again,because the same window appears during re-installation that in removing.... So anyone with brillant solutions,I salute You! Can You help Me? Leroy from Finland |
Re: Unable To Uninstall PT Le 6.9. Win XP Pro
You will probably need to manually edit your Windows registry to resolve this. The particular registry key you would need to remove is:
HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows \ CurrentVersion \ Uninstall \ {8854A2DB-FE59-4352-85A2-2B0411B2CF6C} This will remove Pro Tools from the Add/Remove programs list so when you try to run setup from the cd it will install a fresh copy of Pro Tools rather than bring up the maintenance screen with repair, modify, or remove options. |
Yessirrr!!!
Thank You! LL |
unable to uninstall maudio 6.0.6 driver | jrmusic | Pro Tools SE and Essential (Win) | 0 | 09-19-2012 03:39 PM |
unable to uninstall protools v 8.0.4 | ramonmx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 08-02-2010 10:53 AM |
HELP, I am unable to uninstall Pro Tools LE 7.3!! | PT7USER | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 04-07-2008 08:10 AM |
Unable to Install and now Unable to Uninstall | Blueear | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-14-2006 08:17 PM |
Unable to uninstall 6.9, or get 6.9 running | tjrockstar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-15-2005 09:27 AM |
