Old 11-26-2013, 04:34 PM
justinphilip justinphilip is offline
Default What all does everyone use "Pad" on?
I feel like most inputs including wireless mics need to be padded on my sc48. Am I doing something wrong?
Sensitivity setting on the e835 wireless is at -42db.
With pad on, the gain on the channel is at 12 o clock position (+36db i think).
Old 11-26-2013, 05:12 PM
Default Re: What all does everyone use "Pad" on?
Use the pad on anything that still clips with the gain turned down. Many people set the output level of wireless receivers to line level, which is much hotter than most any wired microphone. When I am in charge of wireless, I set receivers to output a mic-level signal. That way, if I need to swap in a wired mic, gain is still in the ballpark
Old 11-26-2013, 05:49 PM
Mine is at +18dB (the default) on the sennheiser receivers.
What would I turn it down to? Range is -24db to +24db.
Old 11-27-2013, 07:51 AM
Scott Fahy Scott Fahy is offline
Set it to 0db and see how that works with the SC48
Old 11-29-2013, 09:54 AM
I was reading the manual and noticed this..
"Mic inputs have a gain range from +10 dB to +60 dB. Analog line inputs and digital inputs have a gain range from –20 dB to +18 dB."
Does the SC48 treat all inputs as Mic Level? I am used to have a seperate line in jack on the boards..so excuse my ignorance.
Old 11-29-2013, 10:05 AM
Greg C Greg C is offline
I would say that's true for all the AI16 XLR inputs. They are mic inputs that can accept line level inputs as needed using the pad. The 1/4 inputs like the ones on the IO16 and the AES inputs are certainly line level and don't have enough gain for mic level sources.
Cameron Pro Audio
Exclusively at the Miners Foundry
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 03:04 PM
Pro Tools 9 "Pausing" when I press "Play" with Focusrite Scarlett interface eanderso22304 macOS 3 11-23-2011 06:45 AM
PT9 Session Troubles - "Bus Error" in "Main Thread" & Could not complete the Open... tohmit macOS 5 03-23-2011 12:13 PM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
The "FATE" of CM LABS "MotorMix" & "MotorMate". Dum dum dum dum... leon777 Pro Tools TDM Systems (Mac) 21 10-15-2002 12:00 AM
