Old 06-29-2001, 07:29 AM
DEK DEK is offline
Default Orange Vocoder [RTAS]
Just installed this and I'm not clear on how to make an audio track /aux track a Carrier rather than the (non-midi...hmmm?) internal synth. Could someone enlighten me - thanks [img]images/icons/smile.gif[/img]
Old 02-08-2002, 10:46 AM
J. S. Bach J. S. Bach is offline
Default Re: Orange Vocoder [RTAS]
Same here.
You must disable ''Use Synth'' but how do you assign the audio track ?
J.S.
J.S.
Old 02-08-2002, 11:30 AM
lagasus lagasus is offline
Unfortunately, if you are on a TDM system, there is no way to do it. Key input does not function on RTAS plug-ins in TDM sessions. There is a work around:
Put your PT 5.0.1 installer disk in your Mac. Go to the Beta/Bug Fix Folder and drag PT LE for TDM to your Mac Hard drive. Launch PT LE for TDM (it will work on the extensions/DAE for 5.1/5.1.1) and process the audio in an LE session and then import the track back into your TDM session.
I have not tried this yet myself, but it should work.
Since it is not physically possible for the Key Inputs on RTAS plug-ins to work in TDM sessions, the real solution to this would be for Prosoniq to create an H-TDM or TDM version of Orange Vocoder.
Old 02-10-2002, 03:47 AM
PastaViking II PastaViking II is offline
We still need a killer vocoder plug-in for TDM. Nothing comes remotely close to the EMS 2000 I had to sell last year...
Maybe I should get a 3000 this year instead, but I would definitely buy the Orange if it came as TDM...
Orange vocoder rtas problem xes Pro Tools M-Powered (Win) 0 12-03-2006 11:32 AM
Waves transform Vocoder * VS * Orange vocoder syra Pro Tools TDM Systems (Mac) 1 06-04-2004 09:40 AM
Orange vocoder For HD ? Stjernholm Pro Tools TDM Systems (Mac) 3 11-14-2002 07:07 PM
Orange Vocoder RTAS Willistrance 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 05-04-2001 07:00 PM
Orange Vocoder RTAS DigiG4 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-25-2000 12:58 AM
