Converting Sample Rate /Dithering
I am about to master a cd recorded in 24 bit in 96khz .
what should be the right order? First convert to 44.1 and then dither to 16 bit Or first dither to 16 bit and then convert to 44.1 As far as I know the dithering should be absolutily the last thing done Thanks |
Re: Converting Sample Rate /Dithering
right. dither last. convert to 44.1, then dither to 16.
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
Minister is right: downsample to 44.1, dual mono files, 24 bit and the same file format. Then dither/noiseshape down to 16 in a new session.
Assuming that you are finished doing any mastering processes at 24bit 96kHz, definitely do your SRC to 44.1 at 24bits, better still use 24bit TPDF dither during the SRC from 96k->44.1k because the SRC process actually increases the wordlength above 24bits & for the purist results, it needs to be dithered back to 24bits. It's also wise to leave yourself a little bit of headroom with the output of your limiter (-0.3dbfs) so that your SRC has a little room to breath. Once you have your converted 24bit 44.1k file then use a noise shaped dither to reduce the wordlength down to 16 bits. Something like POW-r type 2 or type 3 is perfect for this purpose.
Personally I use Barbabatch for SRC as it can do the 24bit dither during the conversion process & sounds superior to Protools SRC. Matt |
Converting Sample Rate | [email protected] | Windows | 3 | 12-16-2012 05:18 PM |
Converting files sample rate | Mack Truck | Pro Tools 10 | 1 | 05-31-2012 10:25 AM |
Converting Sample Rate for 24>23.976 pull-down | anders | Post - Surround - Video | 1 | 04-29-2006 05:10 PM |
Converting audio into PT, which sample rate? | jwd65 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-20-2005 10:37 AM |
What are you using for sample rate conversion & 16 bit dithering for your PT's mixes? | Pat Thrall | Pro Tools TDM Systems (Mac) | 6 | 02-08-2002 12:29 AM |
