Read it somewhere.
Is this true or totally bs? Also if I open a session made in PT9 will it sound the same in PT10? |
![]() Quote:
I just wish you could run PT 10 HD in native engine mode with the 192 interface I/O instead of some other crappy core audio sound card. |
Thanx Matt!
I wan't sure cuz I couldn't find any info on the site. So Native 10 and HD-Native 10 is 64 bit summing engine and 32 bit plugin bus. And HD also but only with the new HDX cards? |
To all of you guys using PT10... even if it's subtle have you noticed any differences opening a PT9 session in PT10?
furthermore: if they use the same audio engine, does this mean:
1: PTs internal mixing engine is native from now on, and 2: the HDX dsp hardware is only for plug-ins (as UAD/PowerCore cards previously) or, as there are voice additions with every HDX card, does PT use different mixing engines for native and dsp based, technically identical, but one is host based, and the other dsp based?
MacPro 7.1 8c 3.5 GHz, 48GB RAM, HD native PT 2021.12.0, 10.15.7 www.imdb.com/name/nm0501611/ Last edited by matt-o-; 10-26-2011 at 06:12 AM. Reason: clarify |
![]() Quote:
HD systems (excluding HD Native) run the mix engine on the card (DSP for TDM, FPGA for HDX). All other systems use the host CPU to run the mix engine (except HD Native has a cue mixer on the card). Your point 2 is correct: see http://www.sweetwater.com/store/detail/PTHDXcard/ ("all of the HDX DSP processing is dedicated to plug-in power").
https://www.mercurykx.com/artists/luke-howard/ |
Ok, this means, that HDX is even much more powerful, because today normally 60-70% of my HD3 is used for the mixing-engine of PT and barely 30% left for a few TDM only and AUX Plugins. But if HDX uses FGPA, where are the limits? It cannot be with out any restrictions in mixer size???? Anybody has detailed information?
MacPro 7.1 8c 3.5 GHz, 48GB RAM, HD native PT 2021.12.0, 10.15.7 www.imdb.com/name/nm0501611/ |
What's the source on this? I've been combing the web for documentation confirming it. All I find so far is rumors.
David J. Finnamore Nyquist was right. PT 2021.6 Ultimate | Omni | macOS Catalina in a Trashcan 32GB PT 2021.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
Look on youTube for the Avid press event at AES.
Thanks. But. Ugh. It's 48 mins long and the first several minutes, at least, are pure hydrogenated corn syrup.
Pro Tools hangs at initializing audio engine | kasman | Pro Tools HDX & HD Native Systems (Win) | 12 | 05-10-2016 09:20 AM |
Pro Tools 10HD and 5.1 | clunystudios | macOS | 7 | 01-07-2014 05:43 AM |
Pro tools 10 to 10HD? | djmichaelwenz | Pro Tools 10 | 3 | 09-15-2012 10:04 AM |
Pro Tools audio engine is missing | The Bagwhan | Windows | 3 | 01-14-2011 12:56 AM |
M-Audio Delta Control Panel vs. Pro-Tools Playback Engine Question | philip888 | Pro Tools M-Powered (Win) | 8 | 06-12-2009 01:19 PM |
