Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 07-25-2008, 08:26 PM
boknoy1972 boknoy1972 is offline
Default Command Key for Smart Tool is not working..
hi guys! i am new with this forum and just started my DAW project .
Right now i cannot use command keys for smart tools .
I already disabled dashboard function and some keyboard key function and still i cannot use the command keys for smart tool...
Somebody there can help me ?
im using a 2.5ghz macbook pro osx 10.5.4 /m audio profire2626
thanks .
Old 08-06-2008, 03:12 PM
DigiTechSupt's Avatar
Default
Are you possibly referring to the function keys (F1, F2, etc)?
If so - you need to go to the Keyboard & Mouse control panel, then to Keyboard Shortcuts tab and make sure all the F keys are unchecked.
Avid Audio Tech Support
Support FAQ
Old 08-08-2008, 04:16 PM
Default
hi ! and good day.
im referring about the function keys from F4 to F10.
when i'm using smart tool mode and select a region i cannot switch to the sub tools of zoom/trimmer/grabber .
Old 08-08-2008, 04:27 PM
Default
Did you try what I suggested about disabling them in the Keyboard&Mouse control panel?
Support FAQ
Old 08-08-2008, 04:39 PM
Default
hello again ! i already disable all the F Keys and still i cannot use my F1 to F10 command keys. I already follow all the optimization for mac osx .
is there a solution with my F keys problem?
thanks again!
Old 08-13-2008, 02:32 PM
Scott Goldberg Scott Goldberg is offline
Default
thanks again!
Why don't you try using command 7. It's an old command but it works fast and great.
Scott Goldberg
Gold Recordings
http://www.goldrecordings.com
Old 08-13-2008, 03:51 PM
Default
I'm at a loss as to what could be happening. The F keys all work fine on the 2.2ghz MBP I'm testing with.
Do you possibly have some other function enabled?
Which exact MBP model are you using?
Do the F keys work in other applications?
Support FAQ
Old 08-14-2008, 02:33 PM
Default
hello again and good day to all !
thanks scott ! i tried using command+1 to 7 and it is working .
before i installed protools i follow the Mac Guide - Mac OS X Optimizations and Troubleshooting, disable dashboard , follow optimization etc.
F keys is working normally in other application ,but when I'm using Protools F1 F2 F3 are working normal as mac command . i already unchecked all F keys in keyboard shortcut. and still i cannot use my F keys for protools.
I really want to use the F keys for editing because i know its much easier and saves time .
here is the specs of my macbook pro 2008
2.5 ghz
4 gig ram
17 inches hi res glossy display WS LED
200GB hard drive 7200 rpm
hoping there is a solution with my problem .
thanks you so much and more power !
Weird Smart Tool/Selector Tool issue? Marsdy Pro Tools TDM Systems (Mac) 11 01-15-2012 08:22 AM
Get Grabber tool (Object) as part of smart tool? buckaroo Pro Tools TDM Systems (Mac) 8 07-13-2010 05:21 AM
Smart Tool / Pencil Tool in Midi Editor AndyJCP 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 04-26-2009 09:08 PM
keyboard command for smart tool/zoomer toggle? marklee5 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-14-2004 12:53 PM
"Smart tool" not working in shuffle mode AAronc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-04-2002 07:53 AM
