Go Back   Avid Pro Audio Community > Live Sound > VENUE Live Sound Systems
Old 11-01-2016, 07:15 AM
Hitsoundtech Hitsoundtech is offline
Default S6L<-->Profile EQ not compatible
Just a finding from today.
Same CH EQ settings on a Profile and an S6L results in very different response.
(see attached picture)
Settings: HFP@92Hz
EQ1: 147Hz, Q=0.5, +5.4dB
EQ2:851 Hz, Q=1.91, -15.8dB
Buss EQ: EQ3 (7-Band):
Q=0.53, 20kHz, +12dB
the difference is not minor....
I do not know, if this is the desired behavior, or just a bug...
Just did want to let you know.
cheers,
Tamas
File Type: jpg Snare CH EQ comparison_S6L vs Profile.jpg (56.6 KB, 0 views)
Old 11-01-2016, 08:58 AM
RyanJ's Avatar
RyanJ RyanJ is offline
Default Re: S6L<-->Profile EQ not compatible
They are two quite different algorithms.
Ryan John
Principal Product Manager | Avid Live Sound
ryan.john@avid.com
Old 11-01-2016, 09:13 AM
Ok, thanks this is a very important info!
Best,
Tamas
Old 11-01-2016, 04:07 PM
Karel Noon Karel Noon is offline
Are the Algorithms the same in the S3L and S6L or are the S3 users once more left out of innovation and the new algorithm comes with the 5.x software that probably wil never appear on the S3L?
Old 11-07-2016, 08:53 AM
Ist there someone who could confirm or test if the different/new EQ algorithm is also used in the S3L-X ?
Old 11-08-2016, 02:38 AM
Valentyn Valentyn is offline
I don't have full info, but AFAIK EQ was recalculated for S6L simply because of a different sample rate used. This may have included intentional behavior updates. Not really sure if S3L has any changes related to TDM systems or S6L.
Old 11-09-2016, 11:13 AM
Got an answer today through email, so here it is for all of us:
The Algorithm in the S3L is the same as in the older systems, the new one is used in the S6L only.
But due to the different technical Plattform ( TDM vs. AAX DSP ) there still could be a little audible difference.
Profile With 12.5 mastertstudio VENUE Live Sound Systems 0 04-07-2016 01:04 PM
Profile dsp / mix engines noahdh VENUE Live Sound Systems 4 08-28-2013 10:42 PM
Please look at my profile 4times4mil 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 11-24-2006 09:58 PM
profile caruso7r Pro Tools TDM Systems (Mac) 2 05-01-2003 10:55 AM
is there a different HUI profile in 5.0? GROS Pro Tools TDM Systems (Mac) 7 11-25-1999 11:33 AM
