  #51
Old 08-10-2021, 10:15 PM
EddieJones's Avatar
Default Re: *******Fix for Apple Security Update bricking displays*******
Originally Posted by kings79 View Post
Fixed the Orange OLED Eddie but now
- the fader dB levels (When riding faders) are not visible until you hit pause/stop. But only if you hit play/stop closer after riding faders.
- the dB level gets stuck on until you hit play again.
- the little meters on the left get stuck similarly to the dB levels.
- the track labels don't update immediatly if flipping banks/layouts. Pressing stop/play refreshes them to the correct title.
Try doing a full uninstall including prefs from the installer, restart and then reinstall
  #52
Old 08-17-2021, 02:59 PM
Paul Alvarez Paul Alvarez is offline
I just started a new thread on this but just noticed that my issue is a known problem and this is affecting other users of various control surfaces. The first part of this thread shows a fix but dates back to July. Is this still a workaround for S3 (which I am using)?
  #53
Old 08-17-2021, 03:13 PM
EddieJones's Avatar
There's a new official release out in your Avid account and download center. This work around is OK too as its virtually identical.
  #54
Old 08-17-2021, 03:23 PM
kings79's Avatar
kings79 kings79 is offline
I actually did what Ryan mentioned above and the issues went away.
I'll try the new EUCON Workstation Unified Install 2021.6.1 offical and see what happens.
Re-Recording Mixer/Sound Designer
Sydney Australia
OS Monterey
ProTools Ultimate 2022.4
Presonus Quantum 4848
Mac Studio M1 10 Core, 64gig RAM
Sonnet Echo dual NVMe TB Dock
Blackmagic Decklink 3G
  #55
Old 08-17-2021, 03:35 PM
Just decided to try it and it worked. Thanks AVID!
  #56
Old 08-18-2021, 02:18 PM
kings79's Avatar
Tried this as the new official release yeilded the same problems I mentioned above. Will report back.
Sydney Australia
OS Monterey
  #57
Old 08-20-2021, 12:28 AM
Jason D Jason D is offline
UPDATE:
The fix is now officially released.
When I try to install the update, I receive the following message ”The installation failed. The installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance.” I tried uninstalling Eucon first but received the same error.
Does the security update needs to be installed before Eucon can be updated to this version?
I've had all manner of problems since restoring from a Time Machine backup, to the point where I need to re-install the operating system. Before I do that, I'd like to be sure there are no issues with the patch so I don't wind up right back where I started.
  #58
Old 08-20-2021, 08:31 AM
EddieJones's Avatar
Where did you get it from. The official release is in MyAvid accounts or the Download Center. please use that installer. Make sure you are using the right version PC vs Mac.
  #59
Old 08-20-2021, 08:06 PM
I downloaded "EUCON Workstation Unified Install 21.6.1 (Mac)" from the Download Center. I have since downloaded it again but received the same installation error.
It could be related to the issues I am having with my Mac. Since I restored it using Time Machine, many file types will not open from my internal HD but they will open from an external one. I tried installing Eucon from an external drive but it didn't help.
  #60
Old 08-20-2021, 08:13 PM
*******Fix for Apple Security Update bricking displays******* EddieJones Artist Series 65 12-31-2021 10:22 AM
Do not load latest Security Update from Apple Park Seward macOS 5 03-12-2015 06:22 AM
apple security update 2009-002? nst7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-14-2009 11:45 AM
OK To Do Apple Security Updates? hitshack Pro Tools TDM Systems (Mac) 3 11-30-2006 07:29 AM
Apple's security update is out, should i update? Arvid Gunardi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-25-2003 09:00 AM
