Plug-in Delay Compensation
Seems this is only available in the HD version of Pro Tools (came standard on even the entry-level Cubase but hey ho).
So does anybody have any neat fixes to hold back or push forward a particular track for a few milliseconds? - I can't be the only one needing this function? Just recorded some vocals but by the time I'd processed them and loaded the final edits into a session, they were lagging behind the track a bit. Anyone? Cheers. |
Re: Plug-in Delay Compensation
There are 112 work arounds & a ADC plug all over the forum... & just curious, did u track the vocals @ a high buffer rate w/LLM on or a plug a Master fader?
Go here:
http://www.screencast.com/users/peed...ders/tutorials Watch all the videos.. This will show you the "proper" way to manually compensate for delay.. Note that Peeder does not recommend sliding tracks around.
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
I tracked the vocals at the highest bitrate the computer would allow me ... 1 stereo track of the song (mixed-down) for reference and then a mic.
So that's 1 stereo and 1 audio track with no effects. I added a touch of Antares to the vocal and exported and it's annoyingly lagging. I looked at the manual first, then the forum and I couldn't find a definite answer. I wonder if there's anything more annoying than this? - it's been said a thousand times but flipping heck put a switch in there ... there's everything else. |
Great - thanks for this Flommer it's about the 15th time you've helped me on this forum it is appreciated.
I didn't dare open the quantize up then start manually clicking to the left Quote:
Auto tune? That has no latency so I don't understand why u'd get that... OK, I see u said u just have the stereo ref of the track so u obviously bounced it down or som'n from the original session which u say was mixed down, so that's what I'm sayin; Did that session have any thing on a master fader when u mixed it down? Did u print it back in PT & export, or just import that file in the new session? & ACTUALLY, re-reading ur post, u said u track the vocal @ the HIGHEST bitrate the computer would allow so that sorta makes all my questions null & void...
Yeah, interesting point on the Autotune there ... when I turn it on (as an insert on the vocal track) - that's what causes a slight delay. Now I've used AT before and it didn't seem to do that.
I don't have anything clever set up here, just the stereo mix for ref. and a vocal channel. At least it's 'all' slightly lagging ... just on with that video now I'm at the exciting bit discovering that there is a DLY button in the fader. Nearly at the end now |
Oh, I see - you delay every other track except the vocal track.
Hmmm. |
H/W Buffer of 512 (started to break-up at 256)
2 Processors 'on' (dual-core G5) CPU Usage Limit '90%' (max.) Playback 1500ms (which is all I can get out of my rig) So this is usually cock-on, except AT knocked it out a bit. |
Thatz pretty high for tracking but u can only track as allowed of course... Still leaves me with the other questions I asked (I know I said otherwise, but) still would like to know... those could be some other culprits if u noticed this when importing the vocals in the original session...
How much plug-in Delay Compensation do you use? | Hear Me Shimmer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-15-2007 01:09 PM |
LE delay compensation plug ins | nossnevs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-14-2007 11:57 AM |
Plug-in delay and compensation | Purple | Pro Tools M-Powered (Mac) | 0 | 10-22-2006 03:43 AM |
Plug-In Delay Compensation | guitar131 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 10-31-2005 03:31 PM |
Plug in Delay compensation - Do we have it or not | Lizardpoint | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 10-17-2005 07:07 AM |
