new imac and drives questions
im planning to buy a new imac i5 27"
but i need to know impressions of users do i need to get an external drive to run PT? can i use a FW drive? pls help 4mb of ram are ok? |
Re: new imac and drives questions
You should. Just because you can use the Macintosh HD for your sessions does not mean you should.
Yes. I tried. Surely you mean 4GB. Yes, this will be OK.
Since the 27" iMac offers a "two-drive" option, why couldn't you use an SSD for your OS and programs and the "spinning" hard drive for audio? The internal "spinning" drive should be much faster than a Firewire drive. NOTE: SSD's are not yet approved for any purpose by Avid. While 4GB is the maximum amount of memory that can be utilized by the current 32-bit version of Pro Tools, it might be worth going to 8GB if you can afford it. There are various "work arounds" that can take advantage of additional memory for virtual instruments, and many observers (myself included) believe 64-bit Pro Tools will be out in the next year...
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
My thoughts aswell. I would definitley go for a internal two disk solution if shopping a imac today.
The new mac mini and iMac 21.5 with their 5400 rpm drives... | stratquebec | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 10-27-2012 08:05 PM |
Saving for a New iMac/Mac Pro - Which Drives? | djarcey | macOS | 4 | 02-13-2012 11:49 AM |
Saving for a New iMac/Mac Pro - Which Drives? | djarcey | Virtual Instruments | 1 | 02-13-2012 09:50 AM |
New iMac supports two internal drives! | Dism | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 24 | 07-30-2010 09:24 AM |
FireWire drives with Imac intell | K Roche | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-08-2006 12:55 PM |
