recording electric guitar (Picking sounds)
Is there anyway to remove the sound of the guitar pick strumming up and down the strings of a n electric Guitar? I am recording with my guitar plugged into the Mbox and I'm getting constant sounds of my Guitar pick making noise.
Macbook Pro Mac OS 10.10.3 Mbox 2, Pro Tools 11 |
Re: recording electric guitar (Picking sounds)
How do you mean? Are you playing thru an amp sim and don't want to hear your direct guitar sound or something else? Btw what kind of guitar?
I assume you are talking an acoustic guitar. What exact guitar? String type (nylon, steel?). Type of music? What exact Mic(s) do you have?
Lots this is player skill. Mic type and position. etc. not processing in Pro Tools. Try micing close to the sound hole, pointing up on the neck a bit more, more of an ambient mic. All some type of decent condenser mic. Does the guitar have a piezo mic? Then track that as well. And a lot of this might just be that the pick noise dissapers more when in a mix with other instruments. |
If recording acoustic, try a cardioid or even hypercardioid about 12 inches from the 12th fret. Not sure why u would have pick noise on an electric. Do u have a recorded sample?
A Rig: MacBook Pro Spring 2013, 2.8Ghz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph GT 050 Qx3 1.5 TB drives Thunderbolt-FW400, Presonus Faderport. 10 REMOVED! B Rig:MacBook Pro Spring 11, 2.33 GHz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph Portagig 62 portable 1 TB drive Firewired with 400, Presonus Faderport. 10 REMOVED! I am the main songwriter/performer for Midwest Whitetail, Cabela's Deer Nation, Spring Thunder, and Northern Waters Series! |
As nobody seems to have answered your actual question I'll give it a go.
You could try a de esser to try and soften the front of the sound although it can be a bit hit or miss. The best thing I've found is to use RX3 using the de click module, of course this means having to have RX 3 but there is a demo you can try.
Mac Pro, Mid 2010 dual 3.33 Ghz, 64 Gig RAM Mac OS 10.14.5 ProTools Ultimate 2021.6 HD Native PCIe Apogee Symphony I/O Avid HD I/O 192 I/O Waves DLI Apogee Mini Me Mbox Micro |
What you mean like he actually said "electric guitar" in the title and we'd have read the title? (oh oops and body text). No that would be too easy
If the guitar is being tracked though the a DI, then the impact of the pick sound will change a lot as you process that with an amp sim or run it out to reamp etc. I'd be playing with that overall tone/signal chain before worrying too much about the pick sound. And maybe give the player/yourself a softer/thinner pick or playing back the audio to them (monitored in their headphones etc.) and seeing if they can pick differently to minimize the problem might also help. |
You most probably only record too hot, otherwise it's just a matter of learning to mix.
A transient shaper like Waves TRANS-X can take the edge off of pick sounds, but I've only used it on acoustic.
Check the pickups for microphonics and height adjustment.
"In theory there is no difference between theory and practice. In practice there is." - Yogi Berra |
An alternate plugin that has a transient shaper and some other things as well is Izotope Alloy 2.
Recording Electric Guitar | deanc2000 | Getting Started | 1 | 04-03-2013 10:16 PM |
Recording An Electric Guitar | DanielleH | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 02-06-2007 08:24 PM |
Recording electric guitar | ziggy_me | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-18-2007 07:38 AM |
Recording electric guitar | idolizetravis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-13-2005 01:57 AM |
Need advice on recording Electric Guitar | pierbranchstudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 01-03-2003 12:05 AM |
