Old 08-15-2022, 06:34 PM
notr2d2 notr2d2 is offline
Default Hard to Close Playback Engine Window
Hi, I just updated to Pro Tools 2022.7.0 & when I open up Playback Engine, there is no "OK" button to close it. Does anyone have any suggestions? I attached a screen shot.
Thanks so much,
David
File Type: jpg Screen Shot 2022-08-15 at 9.31.42 PM.jpg (66.8 KB, 0 views)
https://adornment.bandcamp.com/
https://andotherwonders.bandcamp.com/
http://gcsband.bandcamp.com
Mac Mini (2012)// OS 10.13.6// Eleven Rack// Pro Tools 2021.6.0
Old 08-15-2022, 07:36 PM
Default Re: Hard to Close Playback Engine Window
You trashed prefs? Always start there. See "help us help you" up the top of each DUC web page. Use Pete Gates PT Prefs utility to make that easy.
You can also try creating a new admin account and test from there.
A suspect cause is you may have got display scaling set to something that helps push the [OK] Button off the bottom of that screen. Play with the Display scaling in macOS preferences.
Still stuck provide the exact display model/screen resolution and scaling settings being used where this happens.
Old 08-15-2022, 09:15 PM
Ben Jenssen's Avatar
Maybe the 'enter' key works, even if you can't see the OK button.
Strange thing, I've never seen that before, or anything like it, and I've used PT with macs for 20+ yrs, across many displays, resolutions etc. My guess is this is PT.
I have a hunch; all the different bug reports we're hearing about on the last few dot updates are because of the code being changed/prepared for apple silicon native, under the hood so to speak. But what do I know.
Life-long audio enthusiast and small studio owner. Retired.
Mac Mini M1, 16GB RAM. 512GBinternal(3000MB/s),2TB(1300MB/s),2TB(350MB/s)
MacOS 11.6.8. PT 2020.12.1 (Reinstatement on hold for M3 macs and AS native PT)
Topping D50 DAC, Dynaudio BM6p, Artist Mix, SSL UC1, EuControl on iPad.
Old 08-16-2022, 04:59 PM
Thanks so much, Darryl & Ben! Pushing 'enter' worked! :)
Old 08-16-2022, 08:19 PM
Eric Lambert's Avatar
Are you still not seeing the OK button?
Old 08-16-2022, 08:43 PM
Still not seeing the 'OK' button.
Side note, lost Falcon with the upgrade so trying to see if I can get an older version that will work with my MAC OS.
Old 08-16-2022, 08:48 PM
People are seeing lots of anomalies with the last .dot updates. I always stay a few steps behind the last update because of this.
But I think it's best you create another thread about your Falcon problem, if you need to.
N key won't open Playback Engine window Firewalker Pro Tools 12 7 12-18-2017 12:52 AM
Video Engine Playback Window Not Working jdgiese19 Pro Tools 12 3 12-19-2016 01:15 PM
External Hard Drive as Playback Engine arturoinletto Pro Tools 11 3 07-08-2014 05:58 PM
When I pick adc in playback engine it wants to close my project Raoul23 Pro Tools 9 2 11-23-2010 11:10 AM
something new in playback engine window x9blade 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-26-2005 09:56 PM
