Re: Do you record drums as separate Audio tracks or Midi?
So that's what I was trying to find out. So that's what I've been doing. As you can see from my screenshot. All my drum recording is in the first track and the output is going to separate tracks for each drum.
Actually can't tell anything from that screenshot; too small.
I use a separate midi track for each group or drums.
Kick Snare Hats toms cymbals the using the midi editor ad make it so that each track has its own color for the nots on that track.. Then I can edit the whole kit together but really clearly see what note is from what instrument. Then each track can have some velocity randomization or whatever is needed... turn the tracks on an off in the midid editor if i just want to focus on one part. Sometimes if will pull in a groove and then split it out to do editing for the particular song.
Jay-J System MacPro 12 Core • 24 G Ram • 10.12.6 PT 12.8.1 • Mbox 3 Pro • Plug-ins Verified 4 HD • OS ssd | Audio ssd | Sample Library ssd | Storage MAXPower eSATA 6G Card • Wiebetech RTX100H-Q Kensington Trackball Works/Orbit Optical Bluetooth off/Airport on and off. |
Thanks everyone for your input and suggestions. I enjoy discussions on workflow and technique, I find them useful and applicable to other things, not just a particular instrument or plugin.
My mind still works in old-school mode where there was a clear line of separation between pre-production and production. Not saying that's better, it's just my comfort zone. So I try to keep the drums parts where they started until "production" time, where I print each part to audio tracks. That could be in a self-contained instrument, like Strike, or MIDI tracks triggering whatever. One suggestion - forgive me if this sounds un-learned, or too complex: what about using the audio track to trigger other drum sounds or samples? I know this is done a lot with live drum recordings, and I have personally never done this - so I don't know which tool would work best, or how easy or difficult it would be to map to a particular library. |
Gotcha. I guess I was assuming that finding trigger points would e easy - I've hear stories both ways. My own experience is only with something similar, I think it was trying to use Beat Detective. With that, I was actually starting with a snare drum audio part, originally recording from a quantized MIDI track. And yes, it was a hassle.
Can I make track 1 the bass drum, track 2 the snare, track 3 the hi-hat, track 4 the first tom, etc... is this possible? I'm using e-drums as a trigger.
....but, if edrums are the trigger then you can split the tracks is like POST #2 on this thread. Multi out of the VI' to AUX tracks
Tracking electronic drums: Separate tracks for each drum?? | johnbarnesiii | Pro Tools 10 | 1 | 11-01-2012 01:20 AM |
How To Record TD-10 VDrums w/ Separate Tracks | sturdystrutter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 08-24-2009 08:13 PM |
Can I record audio tracks live while midi playback is on? | wfasano | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-08-2009 05:55 AM |
Any easy way to sequence MIDI drums over rhythmically imperfect audio tracks? | sehrlangsam | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-10-2008 04:16 PM |
Reason/PTLE Midi drums on separate faders? | taylor4814 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-28-2003 04:41 PM |
