Can you have "center" as default view with multi mono plug in?
Can you have "center" as default view with multi mono plug in? currently it defaults to "L" .
Re: Can you have "center" as default view with multi mono plug in?
Do you mean on a 5.1 track?
Pro Tools Ultimate 2021.10 - macOS Big Sur 11.6 10 Core iMac Pro 64GB RAM - Radeon Pro Vega 56 8176 MB UA Apollo x8 |
yes, for instance, a C1 on a LCRS track, when you open it, even if the channels are linked, it automatically opens showing "L"(left) . it would be very convenient to have it show "C" center.
For instance, with dialog re-mixing; Getting my settings going, I need to view the center to see how things are reacting, like with a C6. It always opens with Left view. very annoying. |
Workaround/Feature :
select Plugin select "C" center new window configuration, label as "Dialog Plugins" (or something) - works with Pro Tools own Multi-Mono-Plugins - I use that to set up all relevant Plugins/Faders for dialog mixing (eg. all 3 faders of the 3 dialog tracks next to each other in the edit window, next to the dialog bus fader, next to the RMS meter on the dialog bus, etc)
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
Nice! seems to work. thank you!
What are the difference between using a "mono" vs "mono/stereo" plug in on mono track | rockguitarist1255 | Pro Tools 10 | 4 | 12-07-2012 08:07 AM |
Viewing center by default on multi mono instances of 5.1? | cocamycola89 | Pro Tools HDX & HD Native Systems (Mac) | 1 | 10-11-2012 02:19 AM |
Toggle Track view ("Opt"+"-") doesn't work | LukeFromBerlin | macOS | 3 | 04-01-2012 04:43 AM |
What would be the "Best" or "General" Quantize default settings? | Norm Mix | MIDI | 0 | 07-10-2009 12:38 PM |
Viewing channels of a "Multi-Mono" plugin simultaneously | Tim R. | Pro Tools TDM Systems (Mac) | 4 | 08-11-2008 03:14 PM |
