PT8 plugin issue.. please help!
Hi all... am still quite new to PT but lovin it! but need some help...
I have installed the Garritan PO4 update which uses the new Aria player instead of Kontakt 2... never had a problem with Kontakt... I have run the Aria player as standalone so know it works, but when i load an instrument track in PT, it doesnt appear in any of the plugin lists.. least of all the instrument list... is there any way to refresh this list??? I know the .dpm file is in the library/application support/plugins folder as i can see it there, and double checked when i ran the installer again that the RTAS option is ticked to install PT support... not sure if there is anything else i can do... as i say, im relatively new to Macs and PT but am computer savvy... but im a bit stuck. Can anyone help??? Anyone else had this issue??? Thanks in advance for any help!!! |
Re: PT8 plugin issue.. please help!
You might want to see if Garritan has a forum... is the update supported for your PT version?
pt9 plugin issue.......help!!!!!!please!!!! | Ibester | Pro Tools 9 | 3 | 01-02-2011 03:17 PM |
Another annoying issue. A good issue, but still annoying. Plugin latency. | DJ Hellfire | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 25 | 05-20-2010 05:26 AM |
Audiosuite PT8.01 Plugin issue | JamesPondAqu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-27-2009 03:07 AM |
CPU Issue with plugin | Boozer007 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-04-2006 08:35 AM |
plugin issue | funkdoctor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-28-2002 12:24 AM |
