automation quit working on one chnl.. (solved)
I'm sitting here mixing a project and the automation decided to stop workin on one chnl... I rewrote it, but nothing! It does'nt move... every other chnl is fine. I'm using PT 7.3, 002R, C24... help quick. thanks, tim
Mac G5, 10.5.8, 2 GB, Rosetta 800 w/X-HD Card, Control24, HD2, PT's 8 http://carterbrothersband.com/studio.cfm |
Re: automation quit working on one chnl.. help quick
can digi step in and help me with this.. where are you guys?
Digi rarely responds on this board as it's a User Conference.
Did you make sure the track's automation status is set to 'read' and hasn't accidentally been turned off? |
oh yeah... read, touch, write, latch, off... everything... what I've done is copy the audio to a new track and that works. but why is automation still not working on the original track? I've had digi respond before to post.. thanks thought, I appreciate it. tim
Yeah, sometimes they do, sometimes they don't, I just wouldn't count on it or get upset if they don't respond - the tech support number/email are there for folks who actually want answers from Digi directly, but it's kind of a carp shoot as to whether or not they'll see anything directed at them on the DUC.
But anyway, back to the problem.... you might just have a corrupt session file. Have you tried creating a new session and importing the troubled track to see if that changes anything? |
no have'nt... creating a new track and copying the audio into that new track has allowed me to have automation... still not on the original, but it will get me by... I'm in the last stages of mixing and it has to be done by Sat.. so this will get me by.. not sure how it got corrupted, I've been working on this session for a while... just strikes me as odd that the automation would not work at all.. thanks for the reply.. tim
Session corruption can cause strange behavior like that.
It looks like you're ok to go at this point, yes? As for when we're here - usually only during the day (8a-5p) M-F PST, but that can vary depending on what were working on. While we're here to help, we mainly monitor to investigate any possible bugs that may be occurring. If we're doing investigation on those issues, we may not be here to monitor other issues. In all cases, there are far, far too many posts on the DUC for us to chime in on every one. If you're posting after business hours, it's extremely unlikely you'll get any reply until the next day, at the very earliest. |
Thanks guys... yep, I'm ok to move forward right now.. just really stumped as to how to fix the problem... cheers, tim
Re: automation quit working on one chnl.. (solved)
This came to me from Digi Support.. Thanks guys.
Hi, It sounds like you have disabled volume automation, you can disabled automation either globally, by parameter, or just on a fader. Go to the menu item Windows>Show Automation Enable and make sure globally suspend or the parameter you are automating is not disabled. You can also disable automation on a per parameter per track basis by setting the track view to the parameter for example Volume and Command-Clicking on it. You can tell that it is disabled when it looks grayed out. It sounds like this is what you have done. Please check to make sure that the you have not inadvertently disable automation on this track. Best regards, Digidesign Technical Support
MP3 Options Quit Working | nanoweber | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-27-2010 08:45 AM |
003 R+: Quit PT, open CoreAudio Manager = no sound!! (><) SOLVED | UltraNEO* | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-04-2009 11:05 AM |
Digi 002 quit working. | bryanjollie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 06-04-2008 06:48 PM |
ProjectMix quit working with PT | JeffGT | Pro Tools M-Powered (Win) | 1 | 03-20-2008 09:54 PM |
Activating the pan on one chnl.. | tim carter | ICON & C|24 | 0 | 02-17-2007 05:50 PM |
