Pro Tools Crashes While Bouncing.
I'm trying to bounce a mp3 using PT with Reason running as a plug in. Pro Tools keeps quitting durrning the bounce.
G5 Dual 2 GHZ PowerPC OS 10.4.11 2.5 GB DDR SDRAM PT 7.1 002 Reason 4 |
Re: Pro Tools Crashes While Bouncing.
Things to consider,
1. Set your Hardware buffer to a high setting 1024 or 2048 samples. 2. Make sure your DAE Playback buffer is set to the default of 2. 3. Check the 'convert after playback option'. If you're still having problems, convert your Reason Instrument(s) to audio. http://www.myspace.com/philogg |
I was set at 1024, defalt, and convert after playback when it was crashing.
I increased the CPU usage limit, in Reason, from 80 to 95% and was able to bounce a mp3. It seems querky but it's the only thing I've changed since my last unsuccessful try. |
10.3.5 crashes when bouncing to disk with MP3 | pshammond | Pro Tools 10 | 1 | 06-12-2013 01:47 PM |
After video editing, bouncing crashes! | sjtae | macOS | 4 | 01-30-2013 05:32 PM |
Pro Tools Crashes when bouncing to mp3? | moonwalker2 | Windows | 9 | 02-29-2012 06:56 AM |
5.1.3 crashes after bouncing | Dynamixaled | Tips & Tricks | 2 | 04-09-2007 06:22 AM |
Pro Tools 6.9 crashes after bouncing to disk | Franco1967 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-21-2005 01:14 PM |
