Re: midi timing erratic even with click on LE 7.3
If you've done everything in the General Troubleshooting thread and are still having the problem, most likely it's due to the unsupported integrated graphics card, which is known to cause this sort of thing:
Thanks for replying Tech support,
Im running Pro Tools 7.3 with the latest patch for this version I havent changed anything to do with bios, the only plugins are Expand and Sample Tank that both came with LE (Sample Tank came with Version 6.8?, the original Of PT Bundled with the MBox2). Im using the MBox2 mini. I havent made any extra changes to my system, beyond for the prerequisites in the quick start guide. I havent done this as there was nothing I read which suggested a possible solution to this problem. My laptop is new, originally came with Vista, Ive used the XP drivers supplied by Dell for this computer to "downgrade" so to be able to run Pro Tools. With so many different problem resolution techniques suggested on the website I dont have the time try every one and I didnt have to do much to solve the same problem with my last computer. Ive ran Sandra on my computer and have supplied just the general specs below. SiSoftware Sandra System Model : Dell Inc. Studio 1555 Processor Model : Intel(R) Core(TM)2 Duo CPU T6400 @ 2.00GHz Speed : 2GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Mobile, Dual-Core Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 2MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing System Platform Compliance : Intel Centrino Duo Mobile Technology Mainboard : Dell Inc. 0C234M BIOS : Dell Inc. A05 (03/20/2009) Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3GB SO-DIMM Chipset Model : Dell PM45 Mobile Controller Hub Front Side Bus Speed : 4x 200MHz (800MHz) Total Memory : 3GB SO-DIMM Memory Bus Speed : 2x 400MHz (800MHz) Memory Module(s) Memory Module : Elpida EBE11UE6ACUA-8G-E 1GB DDR2 SO-DIMM PC2-6400U DDR2-800 (5-6-6-18 4-24-6-3) Memory Module : Hynix (Hyundai) HMP125S6EFR8C-S6 2GB DDR2 SO-DIMM PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Video System Adapter : ATI Mobility Radeon HD 4570 (PS3.0, VS3.0, 512MB, PCIe 2.00 x16) Storage Devices ST9250320AS (250GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache) : 233GB (C:) (D:) (E:) HL-DT-ST DVD+-RW GA10N (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (F:) Peripherals LPC Hub Controller 1 : Dell (ICH9M) LPC Interface Controller LPC Legacy Controller 1 : Winbond W83687THF Audio Device : Dell (ICH9) HD Audio Controller Audio Device : Dell RV730XT Audio device [Radeon HD 4670] Disk Controller : Dell (ICH9) Mobile 2 port Serial ATA Storage Controller 1 Disk Controller : Dell (ICH9) Mobile 2 port Serial ATA Storage Controller 2 USB Controller 1 : Dell (ICH9) USB Universal Host Controller USB Controller 2 : Dell (ICH9) USB Universal Host Controller USB Controller 3 : Dell (ICH9) USB Universal Host Controller USB Controller 4 : Dell (ICH9) USB2 Enhanced Host Controller USB Controller 5 : Dell (ICH9) USB Universal Host Controller USB Controller 6 : Dell (ICH9) USB Universal Host Controller USB Controller 7 : Dell (ICH9) USB Universal Host Controller USB Controller 8 : Dell (ICH9) USB2 Enhanced Host Controller FireWire/1394 Controller 1 : Dell R5C832 IEEE-1394 Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Network Services Network Adapter : Intel(R) WiFi Link 5100 AGN - Packet Scheduler Miniport (Ethernet, 54Mbps) Network Adapter : MAC Bridge Miniport - Packet Scheduler Miniport (Ethernet, 400Mbps) Operating System Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 2) Platform Compliance : x86 I appreciate any suggestions. |
By "secondary drive" does this mean a physical second drive or a second partition? My machine is a laptop which I doubt has room for a second drive and as USB drives are a problem.
This will mean I have to buy a firewire drive, is there any guarantee this will solve the problem? Have there been other cases where the situation we are describing has been solved taking this action? The recording and playback of audio is fine, its just the midi notes that playback erratically. I appreciate the suggestion and yes my other computer does have a second dedicated drive, it initially had this problem too, but the problem was solved a different way (its killing me that I cant remember how I solved it). |
#16
#17
While not supported by Digidesign, eSATA drives with an eSATA ExpressCard could be an answer to a second, external drive. They certainly have a faster transfer speed than USB or FireWire as they are basically plugged into the MB controller like an internal drive.
Cheers,
#18
I have the exact same problem. I think this is something wrong with sending data to click - 'midi in' light in click plug-in window. When I run TL Metro, without linked to session tempo, everything it's all right. But when I use TL Metro, linked to transport+tempo, or DigiRack Click / Midi instrument Click.....
#19
Welcome,
If you have the exact problem, have you tried all of the suggestions offered here in this thread? And here... And here.
#20
Yes, and nothing didn't fix the problem. I removed PT and all preferences, re-install and download last cs7 update. My computer is certified by digidesign.
Click track erratic in Pro Tools 7.3.1 | mbender | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 09-03-2013 05:09 PM |
> PT 8 Intermittent, Erratic Audio Timing | Howardk | Pro Tools TDM Systems (Mac) | 2 | 03-11-2009 11:46 PM |
Erratic timing with MIDI | Olixka | MIDI | 2 | 01-12-2008 08:31 AM |
Click instrument is erratic! | csselement | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-08-2007 08:46 PM |
Erratic Midi Click w/Motu Micro Lite | Oufti | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-17-2003 04:12 PM |
