Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 10-11-2010, 09:42 AM
MMLead MMLead is offline
Default Need help with M-Powered!
I have turned off all software updaters--as advised by Pro Tools. Now when I go to start the program, the Pro Tools software updater locks me out of the program. (the little icon bounces up and down beside the Pro Tools icon) I have to restart the computer, or go through the computer system software updating process before I can enter Pro Tools.
Also--is there a way to define your punch-in points when recording--or are is it only "on-the-fly?" (QuickPunch)
AND--are all Mixdowns REALTIME? Can you edit the waveform AFTER mixdown?
I have been using Audition. I really want to like Pro Tools, because it seems to be the industry standard. BUT--it sure has been a SLOW start. Any words of encouragement from the veterans?
Old 11-02-2010, 01:50 PM
disinfor disinfor is offline
Default Re: Need help with M-Powered!
Can't really help with the bouncing icon. The other ones I can.
If you want to set up your punch in point, create a marker (press the enter key on your keyboard) at the spot you want and move your cursor to that point (or use the marker window/key commands to go to it (to a specific marker its period then number, then period again)). Then, enable Quick Punch. Enable the pre-roll on your transport (click on it) and set it to the amount of pre-roll you want.
All mix downs are in real time. The only way to avoid that is to select the audio you want to bounce out (must be a single track you are bouncing out, not a full mix), and do Shift-Command+K (this is on a mac...PC i'm not sure). But that will export the region in non-realtime.
I'm not sure what you mean by editing the waveform after mixdown. You can always import that wave file into pro tools using File > Import > Audio.
Old 11-09-2010, 06:56 AM
Thanks for the pointers! Some of these things come to light after a little time working with the program. It is just a lot different from Audition---much better in most ways....some ways I'm not real sure yet.
Thanks again.
M-Powered 8 Essential -> M-Powered 8 Upgrade Snowblind Pro Tools SE and Essential (Win) 2 08-09-2011 07:05 AM
mac osx, m powered fast track, pro tools m powered singdance6 Pro Tools M-Powered (Mac) 2 12-22-2010 09:24 AM
Please Advise are Pro Tools M-Powered Essential the same as LE M-Powered? jeremiah0812 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-19-2010 10:10 AM
PT M-Powered with FW400 bus powered audio drive? bruceup Pro Tools M-Powered (Mac) 5 07-06-2006 01:32 PM
bus powered interface + bus powered enclosure ? technician Pro Tools M-Powered (Mac) 0 03-20-2006 05:34 AM
