Old 09-15-2012, 11:23 PM
bacchus40 bacchus40 is offline
Default track sync & re-amping, HD Omni with ELEVEN RACK
posted this on main PT10 discussion to no avail...
has anybody encountered this!?
well, this is a strange one... i am doing some re-amping for a mix and was
aware there would be some delay within the roundtrip from hd omni to 11R and back and I would have to compensate for it... worked fine for bass, was able to adjust H/W compensation using h/w insert to feed my 11R..
now i go to re-amp guitars and for some strange reason, the re-amped signal is actually ahead of the original track when it comes back to PRO TOOLS!??
AM I going crazy here!? i've gotten rid of H/W delay comp. back to 0ms and even tried going with NO HW delay compensation on {usually on short}..
different buffers dont help., audio gets dropped randomly on each record... its never the same.. but always ahead of the original signal..
weather i run HD NATIVE & 11R as playback engine, result is always the same..
of course i can take the track and nodge it forward till it lines up just fine but i'm seriously confused as to how i can avoid this in the 1st place.. hahah... thanks for any/all help..
kickin' at the darkness 'till it bleeds daYlighT
Eleven Rack won't Connect to Omni IO Regg-4 Eleven Rack 1 10-19-2013 11:08 PM
track sync & re-amping, HD with ELEVEN RACK bacchus40 Pro Tools 10 6 09-15-2012 08:41 PM
Fast Track Ultra 8R & Eleven Rack in PT10, Re-amping not possible noiseless64 Pro Tools M-Powered (Win) 0 02-12-2012 11:32 AM
Problems Re-amping with Eleven Rack - PT Aggregate IO tcmoistboy1 Eleven Rack 5 05-05-2011 08:17 AM
Eleven Rack and Pro Tools M-Powered Re-Amping Problems SlowHand2000 Pro Tools M-Powered (Win) 2 10-13-2010 04:04 PM
