Session Problems playing
I got a session today for mixing..Im mixing thru my Saffire 56 and then into my Sonifex for monitoring..
When opening the session I got "Pro ToolsHD DSP,120 Voices This playback is not avaliabe with current hardware.Would you like to continue and use the current playback engine"Saffire" I click ok open session and it wont playback Ive chanaged all the outputs to 1-2 outputs with regard to my Saffire and defaulted the I/O section and still wont playback Changed the sample rate to 48 as it was recorded in that and then it wont budge Any ideas? |
Re: Session Problems playing
How many tracks are in the session?
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
You could create a new session and import the session data, see if that gets it going.
https://www.hybridstudiosca.com/mastering/ |
There is about 20 tracks..so not too many
tried importing into a new session and getting the same problem |
So it sounds like the session itself actually opens, and the actual problem is playback. If you consolidate the audio tracks to the start of the session, you could create a new session and just import the audio instead of the session data. Doesn't really fix the problem, but at least should let you start getting your mix on.
How to preview audio while session is playing? | Dan-Jay | Windows | 3 | 06-22-2012 06:50 AM |
No Sound When Playing Session | Bezo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-22-2005 08:24 PM |
Session not playing some tracks | Ecarter | Pro Tools TDM Systems (Mac) | 3 | 07-10-2004 09:38 PM |
Playing session over internet | fxbuilder | Pro Tools TDM Systems (Mac) | 1 | 08-23-2002 06:09 PM |
Playing a TDM session in a Digi 001 / LE | johnnyonthespot | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 05-22-2002 03:20 PM |
