Old 12-03-2012, 03:33 PM
arnisteinar arnisteinar is offline
Default Waves Plugins Settings not saving
Hi
i'm running Pro Tools 8.0.4
If i open a session and use Waves plugin like the L2 and Linear Phase EQ and they look like this:
http://i1091.photobucket.com/albums/...oX/before1.jpg
and this
http://i1091.photobucket.com/albums/...oX/before2.jpg
when i save the session and open it again none of the settings i set in will be saved and they look like this after i open it again
http://i1091.photobucket.com/albums/...troX/open1.jpg
and this
http://i1091.photobucket.com/albums/...troX/open2.jpg
and the volume is maxed and doesn't change until i reset the Linear Phase EQ
with best regards Arni
Old 12-19-2012, 06:17 AM
Sonic-B Sonic-B is offline
Default Re: Waves Plugins Settings not saving
Similar Problem here, I use the silver bundle from waves integrated to protools m-powered 9!
When I put some of the waves plugins on protools tracks, the settings are completely different the next time I open the session... mostly extreme settings like maximum volume or something!
Unfortunately I don't have a solution for this, but I hope someone else can help us
cheers, sonic-b
Old 12-23-2012, 03:34 AM
Ok I contacted waves support and got the following mail:
Dear Dominic,
There is a known issue on Non-English Windows systems running ProTools.
If you are on such a version of Windows,
Please take the following steps to change the Language Setting:
Go to: Control Panel>Region and Language
and click on the Formats tab.
Click on Additional Settings and make sure that you have the following settings:
Decimal symbol: . (dot)
Digit grouping symbol: , (comma)
List separator: , (comma)
Negative number format: -1.1
Hope this helps.
Let me know how it goes.
In fact, I'm running the german version of windows 7 and did the assumed changes! Problem seems to be solved now!
Saving settings Ivob Pro Tools SE and Essential (Win) 0 03-01-2010 01:41 AM
Saving mix settings Fitzy Tips & Tricks 5 09-30-2008 10:51 PM
saving mix settings stewie Tips & Tricks 1 10-31-2006 11:07 AM
Saving CPU settings in PT 6 Dale-c 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-13-2003 02:04 PM
Saving Plugins Settings to session folder Legs Pro Tools TDM Systems (Mac) 0 09-26-2001 09:37 AM
