I would like to get a new talkback solution over my current sustain pedal switch. I am tired of having to look under the desk to find the pedal and make sure it is turned properly and everything every time I want to say something. I would much rather have a small box on the desk with a switch that I could toggle on and off for talkback.
I've done some research and found out that what I need is a SPST switch or a Monetary Switch to a TS connection. I know I could probably build one myself, but does anybody know of any that might already be manufactured to do this? Also, it would be a huge plus to find one that has a couple switches in parallel instead of series so that it could be toggled on and off by the producer/client as well.
Pro Tools HDX 2025.6 Mac Pro 7,1 3.2 GHz 16-Core Xeon W 160 GB RAM macOS 15.5 Noisebox Studios -Utah Recording Studio |
I use the Shure 450 series II tabletop mic. It has a push button on it that can be locked down if you want and works great. All-in-one deal. No worries about a mic here and a switch there.
It's actually "Momentary" not "Monetary" switches you need. Here's a link to switchcraft's "switches" page.
http://www.switchcraft.com/products/switch-search.html Any one of them that is labeled as "Momentary" will work for you. There are all different types and form factors (some round, some square, some light up, some don't light up, some are hand held, some are designed to be built into a box, some latch, etc...)
Derek Jones Sound Engineer / Producer / Composer Derek Jones Linkedin Megatrax Recording Studios Megatrax Studios Yelp Page A-list Music Artist Page |
I use the Presonus Central Station with the additional remote. It's probably my favorite piece of gear in my studio (ok, next to my Avalon 737!)
Let's me switch monitors and sources easy, and has a great talk back. The other cool thing is that I can use "Y" adapters on the back for pedal inputs,so clients can all have they're own talk back switch. http://www.presonus.com/products/Det...px?ProductId=1
2010 Mac Pro, 3.46 GHz 6 Core Xeon,32 GB RAM, OSX 10.9.5, PT 12.4, RME Fireface UFX, Command 8, Mytek 8x192, SSD evo on System,Audio&Samples on spinner drives WD SATA 64mb Cache |
![]() Quote:
HP Z4 workstation, Mbox Studio https://www.facebook.com/search/top/...0sound%20works The better I drink, the more I mix ![]() BTW, my name is Dave, but most people call me.........................Dave |
Why not try Source Talkback from those nice Source Elements people.
A software switch to give big desk talkback functionality into PT. Works like a dream. Cheers
cheers Mike Aiton BSc (hons) Audio Consultant, Dubbing Mixer/Sound Designer & Journalist BAFTA member IPS member ---------------------------------------------------------------------- www.mikerophonics.com |
Massey has a talkback plug if we're talking software. And I know a guy that loves his Mackie Big Knob (although I'd prefer the API 7800 Master Station).
... but does it help the chorus? |
Before i had the money to shell out for a CR monitoring setup, i used to use a $2 doorbell switch (you know the old-skool ones with the terminals on the back). I used to cut up a mic cable, and wire the switch in the middle of it.
If you spent the time you could make it look ok, or even mount it in your desk... not the greatest looking thing but it was cheap and it did the job!
Pro Tools HDX // 11.3.1 HD // 2x Avid 16x16 HD I/O // 2x 192 I/O // Avid Artist Mix 2012 Mac Pro 12-core // 64Gb RAM // macOS 10.12.1 SSL 4056G |
Source Talkback AAX gets auto talkback | MIKEROPHONICS | Post - Surround - Video | 0 | 11-20-2013 08:15 AM |
Control 24 dim and talkback switches stuck on | Makin' Sausage Music | ICON & C|24 | 3 | 06-08-2009 06:26 AM |
Two Talkback Switches on D-Command | nickmurphy | ICON & C|24 | 2 | 05-07-2007 02:23 PM |
Talkback switches? | CraigLearmont | ICON & C|24 | 4 | 10-28-2005 04:37 PM |
OT- Help! Does anyone know how to set the dip switches on | Basshead3606 | Pro Tools TDM Systems (Mac) | 0 | 05-12-2003 10:42 PM |
