Old 04-03-2024, 07:08 AM
DavRib DavRib is offline
Default Novation SL61 MK2 + PT 2023 - is this possible?
Hello everyone,
I am trying to use the SL61 MK2 to control parameters in Instruments. I have read it should be possible to use MIDI CC Learn on the Advanced mode for AAX Instruments but I have had no success. I can play the instruments (keys and pitch bend do work) but that´s about it.
Automap is pretty much useless for plug-ins, it works in Mixer mode for track levels and pan.
Running everything on OS 10.14, Novation does appear in Audio/Midi Settings, and I have tried different options on the Peripheral Tab, both Automap HUI or SL MK2 Ports.
Thankful for any help
Old 08-20-2024, 12:27 PM
ProTools4's Avatar
ProTools4 ProTools4 is offline
Default Re: Novation SL61 MK2 + PT 2023 - is this possible?
same
NotoriouSS Tad
PT 2023.12 HDX3 maxed system 7,1 Rack Mac Pro
PT 5.1.3 OS9 maxed system G4 1.33
PT 2023.6 & Eucon 2023.6 Work Perfectly Natively, but no connection under Rosetta theodd Avid S1, S3, Dock and Control App 14 10-19-2023 07:23 PM
Does 2023.9 work with os 10.14.6 if i use the 2023.3 driver? [email protected] Pro Tools 7 09-29-2023 05:10 PM
does 2023.9 work in os10.14.6 if i use the 2023 hd driver? [email protected] Pro Tools 1 09-25-2023 09:13 AM
Today's AIR FX and Instrument 2023.3 updates re-install 2023.2! off the wall Pro Tools 9 03-28-2023 10:33 AM
PT 9 recognizes but does not accept MIDI input from Remote SL61 egotrip81 Windows 0 01-04-2011 05:59 PM
