Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 05-06-2022, 02:30 PM
RyanSchwabe RyanSchwabe is offline
Default MTRX Studio unresponsive to DADMan
Hello,
I am having a slightly odd problem with MTRX Studio. MTRX Studio seems to be stuck on manual IP address of 10.0.7.20, but DADMan will not connect with it. When I try to connect with the manual address it does nothing. When I try to switch it to DHCP it still does not connect. I tried to reset the unit to DHCP in recovery mode and that does not help either.
When I right click on the IP address in DADman it only gives me Network Settings options, but both manual and DHCP are unresponsive.
I have tried just about everything I can think of and the unit seems bricked, unable to connect with DADman.
I am on a Mac Pro 7,1 with ethernet into the primary port.
Dante Soundcard and Controller seem to communicate with the MTRX at 169.254.226.158, but dadman keeps popping up with the 10.0.7.20 address and is unresponsive. I have spent so many hours trying to fix this and I cannot find anyone online with this problem.
Has anyone had this issue before?
Any pointers or help is appreciated.
File Type: png Screen Shot 2022-05-06 at 5.03.45 PM.png (29.4 KB, 0 views)
File Type: jpg Screen Shot 2022-05-06 at 4.59.49 PM.jpg (22.8 KB, 0 views)
www.ryanschwabe.com
Old 05-06-2022, 04:03 PM
LDS LDS is offline
Default Re: MTRX Studio unresponsive to DADMan
I don't know if it is a bug in DADman or just the way it works, but my setup also has a 10.0.0.# IP address for DADman control despite the rest of my local network and Dante operating in the 192.168.0.# range with a router dishing out IP addresses.
In any case, it works fine here and you'll only need one network cable to address both DADman control and Dante.
My suggestion would be to do it in steps. Turn off/stop everything Dante related. Hard reset your MTRX Studio (I think there are a couple of reset options based on how long you hold the button down for), and try and get DADman to communicate with the MTRX Studio. Try DHCP for both your Mac Pro ethernet port and the MTRX studio, and see how you go. Remove all other devices from the network and just focus on getting communication between DADman and the MTRX Studio.
Once that is working, try and get Dante working - but, a heads up - I don't think it has ever worked or been supported on the Mac Pro 7,1 internal ethernet ports. Perhaps that has changed with recent updates to Dante for M1 compatibility, but previously a separate ethernet connection like a dedicated network PCIe card or TB to ethernet adapter has been required with 7,1 Mac Pros. Audinate have some stuff about supported TB to ethernet dongles on their website.
Old 05-07-2022, 07:28 AM
creativecontrol's Avatar
The IP address listed under Settings > Device List > Network Settings is likely wrong. This is a known bug which hopefully will be addressed in the upcoming 5.6 DADman version.
With macOS 12.3 or higher, Apple fixed the issue for Audinate of 10GbE NICs in Apple Computers with Dante Virtual Soundcard.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 05-25-2022, 10:52 AM
Reckless Erik Reckless Erik is offline
Had the same problem today. Tried to reset the MTRX Studio with no luck. And to cap it all the MTRX is dead in the water. No front panel lights except a faint power button and DADman does not see the unit at all. HELP!
[email protected]
Newcomer Audio Post
MacBookPro 2.3GHz i7 16GB RAM OSX 10.15.7, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock...
Mac M1 Studio Ultra 64GB RAM OSX 13.6, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock...
Old 07-06-2022, 01:25 PM
For future reference - you may be able to right click on the device ip from Settings > Device ID > and boot into Application Mode if you previously held down the reset (recessed) switch at the rear of the unit > near the footswitch input.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
MTRX Studio and DADMan UI issues Skwaidu Pro Tools | MTRX & MTRX Studio 22 05-18-2022 01:41 PM
No Metering In Dadman with MTRX Studio Cheesehead Pro Tools | MTRX & MTRX Studio 18 03-04-2022 06:43 AM
MTRX Studio Not Detected By DADman nsureit Pro Tools HDX & HD Native Systems (Win) 8 06-07-2021 07:58 AM
DADman disconnecting from MTRX Studio nedd Pro Tools | MTRX & MTRX Studio 11 02-12-2021 07:31 AM
MTRX Studio/DADman feature request Reckless Erik Pro Tools | MTRX & MTRX Studio 6 12-25-2020 09:11 AM
