Old 08-21-2014, 11:54 AM
PT user PT user is offline
Default LOGIC PRO X and Avid Omni issues
Im running Avid Omni with HD Native and I have PTHD 10.3.9 installed. I just installed Logic Pro X. Cant get it going with the Omni. Audio options are only Aggregate i/o. Does the core audio driver come in the install for 10.3.9?
Im on Mac OS 10.8.5 - If anyone is running Pro X with the Omni/HDNative setup I would appreciate some advice as to how to get it going...
Old 12-28-2014, 08:56 AM
Bubba_jam Bubba_jam is offline
Default Re: LOGIC PRO X and Avid Omni issues
I have the same problem with Logic Pro X and Avid Omni. Have you got a solution yet?
Mac Pro 2.93GHZ 8 core 48G Ram, Pro Tools HD 10.3.9 and 11.2.1, Avid Omni, Eleven Rack, Logic X, NI Komplete 9, NI Maschine, Reason 7, Akai MPK49, EZ-Drummer 2, Superior Drummer 2
Old 12-28-2014, 09:21 AM
Hi - use the avid core audio manager found in the avid folder - this overrides system audio . Once active HD Native will appear in Audio Options within Logic
Old 12-28-2014, 11:25 AM
Thanks,
That fix it. But, I also to make sure the clock rate and the buffer was set the same in the Audio/Midi setup under Applications. Mine was not and that prevented it from showing up under Logic Pro X. And the buffer rate was made the audio crackle.
Old 09-02-2015, 02:39 AM
SwirlyD SwirlyD is offline
Hi, this is the method I used to use to get Logic9 to work with my Avid Omni using OSX10.8.5 and PT11HD - however, I have just updated to Yosemite and PT12HD and now, this method does not work....does anyone have any troubleshooting ideas? I have tried restarting everything, opening the Avid Core Manager, then opening Logic and the HD Native option will not appear anymore !
I hope there's a solution....(I suspect either the PT12 driver and/or AirPlay in Yosemite). And the HD Native does not show up with any ins or outs in Audio/MIDI setup :-(
Old 12-29-2015, 07:30 PM
ronstephens ronstephens is offline
Ditto here.
Ron Stephens
ron@stephensfam.net
Pro Tools 11.3.2 HD, macOS 10.11.6, MacPro3,1 (early 2008, Harpertown) Dual Quad 3G w/24GB RAM.
FS:Avid HDX and Omni I/O tripstation Buy & Sell 0 05-13-2014 11:12 AM
Avid Omni for Avid HD 16 I/O+my cash Zeljko2 Buy & Sell 1 12-20-2013 12:45 PM
FS: Avid HD Omni Meads Buy & Sell 1 05-21-2012 06:32 PM
New Avid Mbox clocking issues with Logic Pro 9 chetant 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 05-08-2012 04:04 PM
avid omni ericlees Pro Tools TDM Systems (Mac) 17 11-03-2010 03:08 PM
