kick drum mic bleed
I am having a problem with kick drum mic bleed I get lots of snare bleed.
My basic set up is Apex kick drum mic. I use a 2 1/2 inch foam pad as a tunnel over the kick drum about 32" out atached to the front hoop of the kick drum I place the mic about 2 " away from the skin and start rotaing the mic around in differnt positions pointing at the kick drum. Is it important to have a hole in the front skin as the last 2 clients did not have a mic hole.. or just taking front skin off could be an idea. I was also thing of upgrading to a better mic but not sure if that will help with bleed? any suggestions would be helpfull. Peace all and Merry Christmas. |
Re: kick drum mic bleed
Get a knife and cut a hole in their front head. Stick a mic up in there. Shouldn't have any bleed problems after that.
You could also try gating the kick drum track. |
A few options:
1. Cut the hole for them.. (ha... yeah right) 2. Take the head off.. (Maybe) 3. Record it as is and use SoundReplacer.. If the client doesn't have a hole in the drum i do option 2 or 3.. both work fine. You just need a nice sample for soundreplacer when you do it. But usually any "ok" sound is better then an underwater sounding closed drum kick. Hope this helps
-AIM: RS Recordings -Skype: RSRecords | Pro Tools 8 Native | Windows 7 64-bit| Q6600 @ 3.0ghz | 8GBs RAM | Digi002r | Studio Site: Red Sneaker Records |
To make a nice hole in the drum skin, I've heard of people taking an empty coffee can (metal only) and heating it up on the stove. With a pair of oven mits, remove it and place on the skin for a nice, symetrical hole.
As far as bleed, you might think about investing in a mic made for the frequencies of the kick, like an AKG D112. I own one and have never really had a snare come through on it. I think they are about $199 now. Moving the mic inside of the kick a little will also help. |
Just make a kck tunnel with a blanket. Get good transients and then add a new track, replace and blend.
Doc
MONUMENT SOUND MONUMENT SOUND ON YOUTUBE Monument Sound Facebook "Changing how people hear music one track at a time" |
Hi there,
As a drummer I have some options that you can try: 1: Use other mics--Apex makes some OK starter mics, but in a this situation I would sugest the upgrade to an AKG D112 or at least an Audix D6. Condensers are great for drums, so are ribbons but they will bleed more than a dynamic. Check out your local Long & McQuade and ask them. 2: Build a tent over the kick--You can buy movers blankets from Budget rentals as well as home depot. Make an A frame with an extra HD boom stand(mic or cymbal) and drape the blanket(s) over it to the floor. Then using gaffers tape only, tape the "tent" to the kick shell. 3: Change your placement--Depending on the style of music, try micing the batter head(more punch less boom) I hope this is helpful. -Chris |
what the Doc said... if your client refused to take the head off and you are still getting bleed with your current mic.
just to throw it out there,
i don't really like the AKG D112, I have heard great things about the Audix D6 but have not gotten to use one yet, but I can get a really good sound with my Shure Beta52
www.klarityrecordingstudios.com |
Ah, it's you again...
OK, you have some good solid advice above, try them out. I'd just like to add : -the drum/drummer/room itself are a big part of the leakage. I know.. -having some leakage it's OK, and IMVHO is necessary ! The drumkit is an instrument. Do you mic and gate each individual guitar string separately ? -let the style dictate the amount of leakage and the validity of "replacing" ! Is it dance/hip-hop/ R&B ? Then maybe. Rock ? if the drummer/kit/recording isn't up to standards, then ..maybe. Jazz ? No way ! You get the idea. Contact me for help if needed....I can drive through Georgetown next time I'm going to the studio.. Merry Xmas.. andrew
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
Good on ya Lemix.
Strike: Unable to bleed kick & snare into HiHat track? | StinkyStan | Virtual Instruments | 5 | 05-30-2009 09:21 AM |
Help!! How to handle snare bleed on drum tracks?? | el biciclista | Pro Tools TDM Systems (Mac) | 19 | 11-21-2006 11:20 AM |
How do yall edit out drum bleed? *DELETED* | liquid002rw | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 26 | 01-28-2005 03:33 AM |
Senheiser MD 421 or Shure Beta 52 for kick drum?r kick drum mic? | H-man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 08-16-2001 07:07 AM |
Overhead bleed on Kick track....help!!! | db8 | Pro Tools TDM Systems (Mac) | 9 | 05-06-2000 10:01 AM |
