I searched but couldn\'t find the answer - pls help
I just upgraded to ptle 6.4 and I went to use Reason but I couldn't find the Rewire Plug-in. I know it's supposed to be under "instruments", but all I get is "click". I searched all over the DUC and found a zillion posts but none with the answer. How do I get the rewire plugin? Any help would be greatly appreciated.
thanks G4 733mhz PTLE 6.4 894gig RAM |
Re: I searched but couldn\'t find the answer - pls help
Go to Library(shared not user)/ApplictionSupport/Digidesign/Plugins. If you can see digirewire plugin present, then I don't know what's wrong. If not, then insert your upgrade disc and use the digidesign plugin installer, it's in extras or something. It's been a while but I seem to remember that they were installed seperately.
HD1 2.26 8 core Nehalem PT9.05 OSX10.6.8 |
If you've moved or renamed any Pro Tools or Reason file.. then you'll have to reinstall either one or both apps. Do not move or rename any files associated with either application.. if you want an icon of either app elsewhere, create an alias.
Rail
Thank you! I re-installed both programs and sure enough, Rewire was there! It's good to back in business.
DAE -1127 could not find in Answer Base | Craig F | Pro Tools TDM Systems (Mac) | 3 | 06-19-2009 07:07 PM |
please help cant find an answer on the site | micromaticus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-10-2006 03:59 PM |
I can't find the answer... | dave_gibbon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-22-2005 10:38 AM |
Building computer, have searched answer base | northridgedave | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-16-2003 11:07 PM |
I Know the answer is here somewhere - But I can't find it... | Sparky1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 10-05-2002 01:44 AM |
