How do i tell PT the ending time of my session ??
My session is 1Hr 22 min long..as i'm mixing and adding automation, i notice my session ending time is now 13 hours...i checked and made sure that there are no accidental regions or info that was on any tracks after my official ending time...i don't see anything. What can cause this and how can i tell PT that my session ends at 1hr 22 min...
This does not affect the outcome of my work BUT it's such a pain having to scroll through all that empty space. Thanks |
Re: How do i tell PT the ending time of my session ??
You should be able to change the edit window length by doing the following: -The Edit Window Default Length field can be found in the Setups>Preferences>Display window. Type in the correct length for you session. If you have problems doing this you may have automation events on a hidden playlist or an event you are just not seeing. To delete automation on all playlists try the following: 1 Use the Selector to select a range of data to be removed. 2 Press Control+Backspace (Windows) or Control+Delete (Macintosh). All automation data within the selection is removed for all automation playlists on that track, regardless of whether automation is write-enabled for those controls. Hope this helps, Thanks, Digidesign Tech Support |
Pro Tools 9 crashes every time I open a new session or import session data | Ryan Butler | macOS | 14 | 03-23-2014 07:53 AM |
Vacuum patch gets shorter decay time at 96kHz session than 192kHz session | chrisdee | Virtual Instruments | 21 | 10-07-2011 10:02 AM |
message reads I/O setup has changed since last time session was opened last time | peteor96 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 07-05-2011 08:29 PM |
Beginning and ending session Markers | braddh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-21-2005 04:23 PM |
"Ending Program - should not see me" | kmshroom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-11-2004 08:47 PM |
