Old 02-08-2021, 09:38 AM
arche3's Avatar
arche3 arche3 is offline
Default Re: HDX2 - running out of DSP resources - tips?
Why don't you delete some mixer sub paths and see what happens. Would take about 5 min. Delete. Look at dsp use.
Sent from my SM-G986U using Tapatalk
Old 02-10-2021, 02:04 PM
LDS LDS is offline
I haven't noticed anything specific to Atmos that makes voice and DSP usage different than other formats. It still adheres to the same rules of HDX systems. I generally find I uses voices much quicker in Atmos though, as I use quite a number of 7.1.2 aux channels with native stratus 3d instances on them for workflow reasons.
Using native plugins on 7.1.2 aux channels will chew up 10 voices at a time... Alternative native -> DSP -> Native on an Aux channel will munch up 20 voices. It can escalate pretty quickly.
Your mileage might vary, as I have only ever used HDX 1 with 64 channels of Dante via Atmos mastering suite. Anything bigger, and I just use Dolby Audio Bridge.
Old 02-10-2021, 05:44 PM
smurfyou smurfyou is offline
True, haven't done any Atmos work. But I do know something about PT mixer and that's where your problem is somewhere.
The problem is the number of resources taken up by so many 7.1.2 paths. It's not an issue with his setup.
I always thought subpaths did not use up any additional mixer since it's already using those channels internally anyway.
~Will
Old 02-11-2021, 12:52 AM
nedd nedd is offline
I have HDX2 and use DAPS. One thing that might help a bit is to use 7.1 paths instead of 7.1.2.
I am sure you are not using .2 in this paths and for Strauts 3D, Symphony 3D or Cinematic verbs you would anyway use additional object auxes for .2 (or .4, .6).
Old 02-11-2021, 01:05 AM
kosmokrator kosmokrator is offline
The situation really sucks. You need HDX2 for the required IO, but then run into to DSP-induced voices and mixer-resources hell.
I really hope the hybrid mixing engine for HDX arrives soon and works as advertised.
Old 02-11-2021, 01:08 AM
Well, not quite. We're using quite a bit of 7.1.2 channels. Both for Stratus3D and for Halo Upmixer. I like the flexibility to spread into the heights when needed.
Also, we try to minimize the use ob objects to when they really are neccessary. First, we're only doing HT Atmos where localization in the surrounds is as good with the beds as with objects, and second - and that's the big one - we often want to have additional bus processing, something that's impossible with objects.
Old 02-11-2021, 12:26 PM
arche3's Avatar
So can we conclude the answer is hdx3?
Old 02-11-2021, 12:28 PM
If your problem is voice count then yes
Old 02-11-2021, 01:34 PM
arche3's Avatar
I was wondering about the op question about deleting paths. If he actually tried it.
Old 02-16-2021, 04:23 PM
lucienpalmer lucienpalmer is offline
Default HDX2 - running out of DSP resources - tips?
I’m running a separate DAMS via Dante. I can easily fill an HDX3 for a feature film, but it’s all mixer channels because if the tons of bussing. I still have plenty of voices.
I just make sure to run most of my plugins as native, so the HDX cards have room for all the mixer channels.
Technically, I’m using way more busses than necessary in my mix template with my beds all set to 7.1.2 and three 7.1.2 reverbs in each food group. If I was more careful about only using only the absolutely necessary busses, I bet I could fit it on two HDX cards.
So without seeing you session setup, I’m guessing it’s mostly the bussing that filled up your cards. Try switching all the plugs to native, then if you need more power, delete unused busses.
EDIT: I just re-read your OP, and saw all your plugins are native, so ignore that first part and go to cleaning up your unused or unnecessary busses. The system resources panel will tell you how full you are. Posting a pic of that would help.
Pro Tools Ultimate, HDX3 & MTRX + HD MADI
7,1 MacPro, 3.2GHz 16-core, OSX 10.15
S6 M40 48-5, panners, MPM,Dolby Atmos RMU
AJA Kona LHi, Sync HD
www.ToolshedAudioPost.com
www.TheToolshedStudio.com
Certified for Dolby Atmos Home Entertainment
Need some "tips & tricks" on running dual monitors jglunt2112 Tips & Tricks 4 12-26-2013 04:33 PM
Anybody successfully running a HDX2 on a Mac Pro 8-core Early 2008 Harpertown? Eduardo Apolonia Pro Tools HDX & HD Native Systems (Mac) 7 11-23-2012 12:58 AM
Running out of Juice - Native Plugins hogging resources ? [email protected] Windows 8 05-17-2012 08:37 PM
harddisks and HDX2 mr.armadillo Post - Surround - Video 1 04-23-2012 09:46 AM
Any tips for running Mbox2 on a iBook G4?...... simplescott01 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-08-2006 07:20 PM
