PT 9 ALMOST had me, Avid!! (i'm really crying...)
YOU HAD ME, AVID!! YOU DID! MY WALLET WAS OUT! I'm an LE version 5 and + user... and I was ready to upgrade from PT8 to 9. I was so happy to think that PT9 meant that my bi-software workflow days were 90% over! (Now using PT MP 8 with Cakewalk SONAR PRODUCER 8.5...) I'm just a PROFIRE LIGHTBRIDGE owner who only wants to use his PROFIRE fully to do live show recordings AND mid-budget post-production work! Pro Tools 9 HAD IT ALL.... until I saw this.... NO INPUT MONITORING??? IS THIS TRUE?? Tell me that I'm not getting it right! Might as well ask a painter to paint with his eyes shut! (... I know, he could paint abstract paintings... so I guess I'll have to produce abstract music??) No input monitoring = deal-braker... I understand that AVID still wants to give their best products to the HD customers, but... sigh. SO... i'll still be recording about 32 tracks of audio using SONAR, then export those to Pro-Tools when I can afford to go in a "big" studio. AND I'm still going to import OMF sessions in SONAR and do post in it even if I know that I prefer to mix in PT... (not to mention here the absence of the SMPTE timecode in PT MP...) AVID, you ALMOST had the good logic here, regarding some kind of a project-flow!! Something like "from the low-budget projects found in communities INTO the big production (HD equipped) facilities when budget allows it!" ... but do not worry, SONAR X1 will not get my money either this year... SOBS...
TacosFame Producer / Musician M-audio Profire Lightbridge Yamaha 01v96 Behringer ADA8000 PT M-Powered 8 Win 7 64 bits Dell Studio 17 (core I7) Sony Sound Forge / CD Architect / Vegas Cakewalk Sonar Producer 8.5 ADOBE CS5 |
Re: PT 9 ALMOST had me, Avid!! (i'm really crying...)
I just checked and it has the same "Input Only" monitoring and "Auto Monitoring" as before...
REALLY?? Whew!!
I GOT IT WRONG! HURRRAY !!! PT does allow INPUT MONITORING ! I'm just to dumb to understand correctly the first time !!! ... but i'll check the feature-list again after having a little beer... I was just a little dumb... woohoo... just a little .... woohoo... PT 9 !! LOL! Thanks for your answer. I'll calm down eventually...
IIRC, Input Only monitoring will switch all record-enabled tracks to incoming audio while playing. So what's missing is input monitoring SOME of the record enabled tracks, or hearing incoming audio for tracks that are not record enabled.
Kevin Windrem Sweet Spot Sound |
If PT9 still handle things about input monitoring as it did in version 8, I am happy with it!
In live situations, I want to listen to every track... i just MUTE the ones I do not need to listen to at a given time. GREAT News for me... at last! I'll get the VST wrapper and a decent multi-band compressor into PT 9 and mix away!! Sad that I sold my DIGI 002 only a couple of months ago... LOL Now i'll double-check the feature list about mixing and automation, as I suspect something might have been stripped-down a little there... but surely I am wrong about that...
According to the comparison list only HD native has input monitoring! Just a heads up on the wrapper and VST's. it only works with VST2 not VST3 Chris
Rail
Platinum Samples www.platinumsamples.com Engineered Drums for BFD |
I'm still wondering if we can turn the monitoring off completely. I just want protools to play what is on the track ONLY even during punch in. Just play, arrive at punch, record (silent), arrive at punch out, play track. No mute button toggling, no input button, nothing, just my punch selection and the ; & p keys (stacking ewww - someone's gotta do it). "Track only monitoring" is what I want. I use a FF800 for the CR and HP mix, does a great job at all of this, no need to get the delayed vocal mixing in with the "no-latency" vocals problem once I'm punching in. *Still buying it though can't resist, they have pretty much listened to what everyone was asking for and put it in the release. |
That's a very unconventional work flow and not supported. We used to use the Dolby 361's back in the day to do that only because we didn't have Input Switching on the 3M 79.. but since Pro Tools has Input Switching it's not a big requirement.
You could try unlinking the Record and Playback faders and put the Record fader at infinity... but I'd suggest using a more conventional (1980's) workflow. Rail
But, its unconventional to you, not to everyone. Nuendo, Logic, Sonar, Live have had this feature for a long time. I'm not saying that they are superior in any way as every DAW has its quirks, just that it is conventional to a degree. |
Unable to locate Avid hardware. Avid Pro Tools SE 8.0.3 (M-Audio KeyStudio 49) | azndisast3r | Pro Tools SE and Essential (Win) | 3 | 09-21-2013 02:31 PM |
Will (Avid/M-Audio) Pro Tools MP 9 support Avid Vocal Studio: Producer USB Microphone | XDosShane | Windows | 0 | 02-04-2012 09:17 PM |
Stop crying and make music !!!!!!!!!! | Litemup | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 16 | 09-03-2009 11:58 PM |
have you ever seen a grown up man crying? | ariel keshet | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 03-17-2005 07:40 PM |
Crying over PTLE 6.4 problems! HEEEELLLLP Please? | TheMadStudent | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 03-12-2005 07:28 AM |
