PT not reliably starting play
Hi All.
I think this problem began to appear for me around 7 or so, it remains in 7.4. I can load up a new project, no plugs and press play, sometimes it plays, sometimes it doesn't. Sometimes I have to hit the play button a few times to get it going. Doesn't make any difference with audio or instrument tracks. Have mucked around with buffer settings to no avail. Also tried different FW ports, no difference. Performance is stellar otherwise. But, it's like it's not preloading buffers or something... What's going on? |
Re: PT not reliably starting play
Its probably your computers memory. I had a very similar problem, I upgraded my RAM and dont have the problem anymore...
What was the similar problem you had? I have a sneaking suspicion it might be something to do with the Asus P5K onboard sound. Haven't checked it out full y yet, but seems to happen less when it's disabled. |
I had this problem and it went away when I installed the microsoft dual core hotfix.
About the memmoery you can verify you'r memorry buy using memtest 86+. download, then burn a bootable cd, then boot from the cd and let the test run for a couple of hours. edit: I have networking and sound enabled on my P5K SE (same as P5K but no FW and less sata connectors/no raid...) so I dont think its related to either.
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9 |
PT9.0.1 and new Avid MBoxPro. Does this work reliably for anyone?? | lancemcv | macOS | 39 | 09-13-2011 09:04 PM |
play back not starting at cursor position | garnoil | Pro Tools TDM Systems (Mac) | 35 | 05-09-2008 08:33 AM |
Play button flashes before starting | jonathans9 | Pro Tools TDM Systems (Mac) | 5 | 04-19-2008 02:09 PM |
Loud Pops at edits(punch points), starting and stopping play | dw_deej | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 12-10-2007 03:57 PM |
play location returning to starting position | Micah777 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-18-2005 07:27 PM |
