PT 8 adjust Tempo with drum loop
Hi
I'm sure this is a simple one but I can't seem to work it out. I have a loop of one bar. I don't know the loop's tempo. How do I get PT to set the tempo to the correct amount? i.e I want (if poss) for PT to correctly calculate the tempo. And what if I have a selection of loops that I'm editing together that a real and so may have slight tempo variations? What's the best way? Is there a video tutorial anywhere? Cheers. |
Re: PT 8 adjust Tempo with drum loop
I think I've worked it out.
Correction, I haven't
Conform them to Tempo.
filosofem |
To lock your beats to the grid there is more ways to achieve this:
Identify Beat Select your audio loop and use Event -> Identify Beat to find out the original tempo of the loop. This will change PT's grid to the tempo of the audio. The audio will not be altered. Elastic Audio Analyze your audio with EA (rhythmic in case of drumloops). Then quantize your audio to the grid using Event -> Event Operations -> Quantize. This will change the tempo of the audio and match it to your session's tempo. Beat Detective Select your loop and open Beat Detective, analyze the audio and quantize it - all from within Beat Detective. This method also changes the tempo of the audio and was used before there was Elastic Audio. The results should be the same. Sometimes it is better to use this version, sometimes EA wins. Try it... Here is a video where a combination of the first two versions is shown: Hope this helps...
MBPr 15" (Mid 2015) i7, PT12.4, Studio One 3, UA Apollo Quad Firewire |
Great, thanks for that. What's ADC?
Preview Controls and Indicators Page 249 Pro Tools Reference Guide. Furthermore DTV Pro Tools Accelerated Videos Pro Tools 7.4 - Making Audio Files Elastic.
filosofem |
Automatic Delay Compensation
Here I am, after time not long... and thankful for the break, What I found when I got there, was that I couldn't stay away! Hobo Shave! |
Need to get drum loop to match sesssion tempo? | Tom Hartman | Pro Tools TDM Systems (Mac) | 2 | 10-28-2010 05:58 PM |
audio drum loop tempo change | Kluson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-22-2008 03:09 AM |
How To Find A Tempo From a Drum Loop??? | CHEEZGRITS | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-16-2005 07:26 PM |
Conform drum loop to new tempo? | The Eggman | Pro Tools TDM Systems (Mac) | 19 | 07-27-2002 06:17 AM |
How to adjust the tempo of my loop | Loops | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-15-2002 02:29 PM |
